Topic: Interrupt Handler Names on Due (Read 2925 times) previous topic - next topic
AndiJay
Hello all,
It's my understanding that on the AVR board you do something like the following to set up an interrupt handler.
Code: [Select]
IRS(vector)
Where vector is the name of the interrupt vector you want to handle.
How is this done on the Arduino due?
All I can find is a file called "interrupt_sam_nvic.h" located at:
arduino-1.5.2-windows\arduino-1.5.2\hardware\arduino\sam\system\libsam\include
In here there is a comment which states
Code: [Select]
* For NVIC the interrupt vectors are put in vector table. So nothing
* to do to initialize them, except defined the vector function with
* right name.
My question is, what is this "right name?" where are they defined, and do I simply do the following?
Code: [Select]
ISR(right name)
assuming I have the right name?
Thanks
exedor
It depends, what are you trying to do an interrupt for?  If you just want an interrupt on one of the pins, use attachInterrupt(pin, function_name) and detachInterrupt(pin).
The Due supports arbitrary interrupts on all pins...you are not limited to 2 or 3 or 4 (or whatever the Uno has.)
If you are talking about timers that's substantially different and more complicated and has been discussed extensively here:
http://forum.arduino.cc/index.php?topic=130423.0
cappy2112
The Uno also supports interrupts on more than 3 pins. The limiting factor on the Uno is that you still only have 3 interrupt vectors.
The user still needs to figure out which pin was interrupted.
This library makes it easier, but possibly at the cost of response time.
http://playground.arduino.cc/Main/PinChangeInt
