Topic: Connect arduino to mpr083 (freescale touch sensor) (Read 1 time) previous topic - next topic
naf18
Good afternoon.
I'm doing a projects which consists in do a touch sensor.
So i decided use the freescale touch sensor MPR083.
However I have many problems in use the wire library.
What happens is that the arduino crashes when it goes execute de code: Wire.endTransmisson.
The code that I do is:
#include <Wire.h>
  Wire.begin(); // join i2c bus (address optional for master)
  Serial.println("vai escrever");
  Wire.beginTransmission(0b10011010); // transmit to device #4
  Wire.send(0b00001010);        // sends five bytes
  Wire.send(0b00010101);              // sends one byte
  Wire.endTransmission();    // stop transmitting
  Serial.println("escreveu");
Anyone can help me to do this project?
TKS
ArduinoM
Have you tried sending the numbers in hex?
Why would sending the number 10 send five bites?
and 21 for sending one byte?
What does the datasheet say?
naf18
yeah, I forgot delete the comments. It was copy paste of an example code.
The datasheet doesn't have nothing about the code.
metRo_
How you can see here:
it's 1001101 for adress and 0 or 1 to read or write.
naf18
Ok i understand that but isn't it what i put?
Look:  Wire.beginTransmission(0b10011010) , the firsts seven bits are the adress and th last is the instruction to write.  Am I correct?
