Topic: Arduino Due DS3231 (Read 3601 times) previous topic - next topic
bastukee
Is there by any chance a DS3231 or equivalent library for the Arduino Due?
No trees were harmed by the transmission of this message. However a few million electrons were temporarily inconvenienced.
bastukee
#1
May 29, 2013, 03:01 am Last Edit: May 29, 2013, 03:27 am by bastukee Reason: 1
I believe I have solved my problem, I used this example, modified the deprecated wire commands and it works great.
http://www.l8ter.com/?p=417
I believe that the DS3231 should work with the DS1307 library, but I have not used it...
Code: [Select]
#include "Wire.h"
#define DS3231_ADDRESS 0x68
void setup(){
  Wire.begin();
void loop(){
  printDate();
byte bcdToDec(byte val)  {
// Convert binary coded decimal to normal decimal numbers
  return ( (val/16*10) + (val%16) );
void printDate(){
  // Reset the register pointer
  Wire.beginTransmission(DS3231_ADDRESS);
  Wire.write(0);
  Wire.endTransmission();
  Wire.requestFrom(DS3231_ADDRESS, 7);
  int second = bcdToDec(Wire.read());
  int minute = bcdToDec(Wire.read());
  int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
  int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
  int monthDay = bcdToDec(Wire.read());
  int month = bcdToDec(Wire.read());
  int year = bcdToDec(Wire.read());
  //print the date EG   3/1/11 23:59:59
  printDigits(month);
  Serial.print("/");
  printDigits(monthDay);
  Serial.print("/");
  printDigits(year);
  Serial.print(" ");
  printDigits(hour);
  Serial.print(":");
  printDigits(minute);
  Serial.print(":");
  printDigits(second);
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
jonmcosgrove
Old post, but for what its worth, the DS1307 'RTClib' library does seem to work with the DS3231 on the due, at least initially....
ghlawrence2000
I too can confirm the DS3231 works fine with the DS1307 rtc lib, but might I also suggest an alternative as http://www.rinkydinkelectronics.com/library.php?id=73.
Regards,
Graham
UTFT_SdRaw now included in library manager!! ;) High speed image drawing from SD card to UTFT displays for Mega & DUE.
UTFT_GHL - a VASTLY upgraded version of UTFT_CTE. Coming soon to a TFT near you! 8) Shipping April 1 2016!
rockwallaby
#4
Apr 07, 2015, 12:32 pm Last Edit: Apr 07, 2015, 02:24 pm by rockwallaby
Thanks Graham, I'll add that to my library list.  :)
I'm coding a few projects up at present using the DS3231, for both DUE and AVR and have found two other sources for libraries.
First is what I use and is based on the DS3232 which is the same as DS3231 except the DS3232 has two programmable alarms and 263 bytes of read/write SRAM.
https://github.com/Tecsmith/DS3232RTC
EDIT:
For above library, you will need to make a small change of instantiation in both the .h and .cpp file as follows:
Header, change at line 116, RTC to someting like RTC_DS3232
Code: [Select]
extern DS3232RTC RTC_DS3232;
Source file, change same again at line 530:
Code: [Select]
DS3232RTC RTC_DS3232 = DS3232RTC();  // instantiate for use
To avoid clash with SAM RTC.
Next is for DS3231, but may not tie in as well with the 'Time' library as the above library.
http://rweather.github.io/arduinolibs/classDS3231RTC.html
____
Paul
Paul - VK7KPA
