Topic: has anyone used USART1 as spi sucessfully ? (Read 868 times) previous topic - next topic
ralphnev
the reason i'm asking is :
i want to use a PDC, which can be used with the USART & not with spi0/1
I'm guessing i have to modify pins in variants.cpp for digital outputs for the strange selection of pins
(A11-A16)
code so far:
Quote
void setup_spi()
    USART_SetTransmitterEnabled(USART1, FALSE);
    USART_DisableIt( USART1, 0xffff) ;
    USART_Configure(USART1,US_MR_USART_MODE_SPI_MASTER,  4100000, VARIANT_MCK);
    USART_SetTransmitterEnabled(USART1, TRUE);
    pmc_enable_periph_clk (ID_USART1);
int spiout (void * buffer, uint32_t bufSize)
    USART_WriteBuffer(USART1,buffer,bufSize);
return usedSensorWidth;
Graynomad
Quote
Why does it need a USART, if the USART is in SPI mode what's the difference?
_____
Rob
Rob Gray aka the GRAYnomad www.robgray.com
ralphnev
as stated:
the two SPI peripherals can not use PDC, USART(1-4) in spi mode CAN use the PDC
Other chips of the same family spi periphieral can use the PDC ...
why they don`t on the SAM3x8 .. no idea
Graynomad
Oh yes, sorry I was thinking an external protocol. You can't use the DMAC?
_____
Rob
ralphnev
for one application yes/ suppose so ..
looks more complicated than the PDC (& which i've used already  ... )
hmmm ...
but fot the other application / I can't because i would like to use the spi for SD card access
(using the USART as a fifo gateway to store data in an external memory)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
