Topic: Using the I2C PCF8563 Real Time Clock (Read 10658 times) previous topic - next topic
xSmurf
I haven't really tried in a while. By now I've worked with a few other I2C devices like maxim's ds1337 RTC. I'm pretty sure the PCF8563 could work too. But for a safe bet use the ds1337 as there's a lib for it. Here's the code, config1 & config2 and usage doc. The only hitch is the 32.768Khz crystal needs to be a 6pF for accurate timing (12pF seems more common). From what I read in the datasheet at 12pF the skew could be ±1min/day. I'm not sure if that's also the case for the PCF8563.
Jonen
Sorry for bringing this old thread up again but i really wan't to get my pcf8563 up and running...
I made som changes to your code, just to get it up and running but whit out success...:
#include <Wire.h>
void setup(void)
 Wire.begin();
 Wire.beginTransmission(0xA2);
 //Wire.send(B00000000);
 Wire.send(B00000000);  // 00H      Test mode
 Wire.send(B00000000);  // 01H      Alarm mode
 Wire.send(B00000011);  // 02H      Seconds
 Wire.send(B01000101);  // 03H      Minutes:p
 Wire.send(B00010100);  // 04H      Hours
 Wire.send(B00010101);  // 05H      Date
 Wire.send(B00000101);  // 06H      Day of the week
 Wire.send(B10000111);  // 07H      Century bit 19XX = 1 | 20XX = 0
 Wire.send(B10011001);  // 08H      year
 Wire.send(B10000000);  // 09H      Minute alarm
 Wire.send(B10000000);  // 0AH      Hour alarm
 Wire.send(B10000000);  // 0BH      Day alarm
 Wire.send(B10000000);  // 0CH      Weekday alarm
 Wire.send(B10000011);  // 0DH      CLKOUT control (00: 32.768Khz 11: 1Hz)
 Wire.send(B00000000);  // 0EH      Timer control
 Wire.send(B00000000);  // 0FH      Timer
 Wire.endTransmission();
 Wire.send(0x00);
 Wire.requestFrom(0xA2, 0x10);
 while(Wire.available())
   Serial.println(Wire.receive() ,BIN);
 Serial.println("Waiting a little");
 delay(2000);
And i get an response like this:
11
1000101
10100
10101
101
10000111
10011001
10000000
10000000
10000000
10000000
10000011
Waiting a little
Now, the strange thing is that when i RTC from my arduino I get the same response. Well, thats strange, if it's not connected you should not get any response right, but you do, it's the same when I try your code and remove the PCF8563...
Does anyone else experience the same thing or is it only me?
Thank You
/J
xSmurf
Yes, if the address is invalid you'll read back the buffer. Look on this forum, I have a post describing how to modify the TWI library to enable scanning of addresses. My bet is you need to shift your address by one to the right (>>1).
Jonen
No, same result... :( Really starting to get on my nervs....
Any suggestions?
Thanks
/J
xSmurf
Jonen
Scanner? if your refering to http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1192228140/1#1 I can't seem to get it right, I know the 312a313,324 markings indicates changes to some rows some how, but it makes no sence...
It would be really nice could take a moment and explain... I'm really nooby at this stuff....
Thanks
Jonen
Got it to work now, thank you, as it turns out it was a bad wire that was the problem, the clock pin never got to the rtc... My current code is:
#include <Wire.h>
void setup(void)
 Wire.begin();
 Wire.beginTransmission(B1010001);
 Wire.send(0x00);
 Wire.requestFrom(B1010001, 0x10);
 int i = 0;
   Serial.print(i,HEX);
   Serial.print("\t");
   i++;
 delay(1500);
It might help someone... The only problem now is that i don't get any clock out.. but thats probably some smal error...
/J
The scan function would be useful though....
xSmurf
Here's the post with the scanner http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1192228140/1#1. You can also look at the http://mlalonde.net/cral/ for the library used for handling the ds1337 RTC. You could possibly port it to the PCF8563.
lucasvickers
I'm having a similar issue with an address > 127 but I'm just confused:
My address is 164, too large for Wire by default.  So I truncate the LSbit and then I can use the address.
Wire will take care of the read / write bit.
Ok but still,
If my previous address was B10100100, how is wire going to differentiate my address with the LSBit dropped and an address of this value?
ie how does it know that my
 B1010010 does not equal
B01010010
it just makes zero sense to me?  There's gotta be some way to signal to the Wire library that it's getting a truncated address.  I've successfully used the wire library on address 104, so it's not like it just ignores a bit by default?  What I mean is the manufacturer said the address is 104, so I handed Wire 104, and it worked fine.  I did not have to truncate the bit by default.  If you don't truncate by default, how will Wire know you truncated a bit, or does it just not support addresses above 127?
Thanks for the help
Lucas
Jonen
ok, if you have an address like you specified B10100100 the address that you give the wire library is B1010010, i.e you remove the last bit(the lsb). then when wire is going to use the address it will add ither an 1 or 0 to the end depending on if it's writing or reading to the device 0 for reading and 1 for writing if i'm not wrong... so it will be like this:
B10100100 (reading address)
B10100101 (writing address).
So to sum this up, when you specify an address to wire, you only give the first 7 bits and the library will add the last bit by it self depending on if its writing or reading from the device...
/J
lucasvickers
But if I hand it a pure int, instead of 7 bits, it will just use that address directly?  Because that seems to be what happens.
Thanks!
xSmurf
#26
Mar 16, 2008, 06:49 pm Last Edit: Mar 16, 2008, 06:58 pm by xSmurf Reason: 1
Conversion from integer to unsigned char will lose data. Aka, if you're trying to fit a 16 bit number inside 8 bit, the top 8 bit will be truncated. But that's in the best of world. Incompatible sing conversion will often result in unwanted/unpredictable behaviour. On another note. Yes a lot of datasheet mention the address as 8 bit, even when others from the same manufacturer give them as 7 bits. As such, if your address is over 127, it should be shifted to the right by one. As mentioned previous the Wire library already takes care of making it an 8bit address with the proper w/#r address.
Hope this helps.
Yan78
Thank's a lot Jonen ! Now my clock is working !  :)
