Topic: UNO SD WAV Player with IR remote. (Read 3600 times) previous topic - next topic
ganeshkubade
Please help with my code what wrong with this code ? it only plays first wav file and stops.
#include <SD.h>                      // need to include the SD library
//#define SD_ChipSelectPin 53  //example uses hardware SS pin 53 on Mega2560
#define SD_ChipSelectPin 10  //using digital pin 4 on arduino nano 328
#include <TMRpcm.h>           //  also need to include this library...
#include <IRremote.h>
TMRpcm tmrpcm;   // create an object for use in this sketch
char mychar;
int RECV_PIN = 6;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
irrecv.enableIRIn();
tmrpcm.speakerPin = 9; //11 on Mega, 9 on Uno, Nano, etc
  if (!SD.begin(SD_ChipSelectPin)) {  // see if the card is present and can be initialized:
    Serial.println("SD fail");
    return;   // don't do anything more if not
  //tmrpcm.play("1.wav"); //the sound file "music" will play each time the arduino powers up, or is reset
unsigned long last = millis();
  void loop(){ if (irrecv.decode(&results))
    if (results.value == 0x40BD00FF)
      if (millis() - last > 250)
      last = millis();
    if (results.value == 0x40BD807F)
        tmrpcm.play("2.wav");
      last = millis();
    if (results.value == 0x40BD40BF)
        tmrpcm.play("3.wav");
      last = millis();
    if (results.value == 0x40BDC03F)
        tmrpcm.play("4.wav");
      last = millis();
    if (results.value == 0x40BD20DF)
        tmrpcm.play("5.wav");
      last = millis();
    if (results.value == 0x40BDA05F)
        tmrpcm.play("6.wav");
      last = millis();
    if (results.value == 0x40BD609F)
        tmrpcm.play("7.wav");
      last = millis();
    if (results.value == 0x40BDE01F)
        tmrpcm.play("8.wav");
      last = millis();
    if (results.value == 0x40BD28D7)
      last = millis();
PaulS
Functions start in column 0. Nothing follows a { on the same line.
Your formatting is horrid. Fix that if you expect any help.
ganeshkubade
Formatting means what do you want to say ? pls clear i can't get your point .
AWOL
peterengland
AWOL
It fixes abominations like this
peterengland
But IDE returned following error .
java.lang.ArrayIndexOutOfBoundsException: 20
AWOL
Is there a particular reason your IP address is the same as member "ganeshkubade"?
peterengland
Yes i Am owner of that two accounts one that created just now.
peterengland
I need to change my name of account ..
peterengland
ganeshkubade
oh I don't know that is illegal ,, sorry for that,, you already banned my account  :)
AWOL
If you want to change your name, change it, but don't create sock-puppets
ganeshkubade
I am very very sorry.. I never do it from now.
