Pages: [1]   Go Down
Author Topic: Interact and control a LED using the Serial monitor  (Read 968 times)
Offline Offline
Newbie
View Profile
Hello, I want to control a LED, set it to either HIGH or LOW, by sending values through the serial monitor.
Here is one example of something similar, but I dont know what the Arduino code he uses looks like:
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=32&t=37469
I tried with this code, but it does not work:
Code:
const int ledPin     = 9;
const int ledPin2   = 10;
void setup(){
void loop () {
     if (Serial.available()>0) {
      //int d = 0;
      int d= Serial.read();
            if ( d == 10 )
              digitalWrite(ledPin, HIGH);
              digitalWrite(ledPin2, HIGH);
            else if ( d == 20 )
              digitalWrite(ledPin, LOW);
              digitalWrite(ledPin2, LOW);
I simply plugg the Arduino into my computer, open the serial monitor and put "1" into the send text field and send it. RX LED on the Arduino flashes when I do this, but the LED does not go on. Anybody know what im doing wrong here?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
The serial monitor sends code in ASCII, so when you type 1 it actually sends a value of 49.
Look at the example in the arduino IDE for this under serial communication.
Logged
Offline Offline
Newbie
View Profile
Thank you!
Logged
Pages: [1]   Go Up
Jump to:
