Topic: Interact and control a LED using the Serial monitor (Read 1 time) previous topic - next topic
vivacatalunya
Hello, I want to control a LED, set it to either HIGH or LOW, by sending values through the serial monitor.
Here is one example of something similar, but I dont know what the Arduino code he uses looks like:
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=32&t=37469
I tried with this code, but it does not work:
const int ledPin     = 9;
const int ledPin2   = 10;
void setup(){
void loop () {
     if (Serial.available()>0) {
      //int d = 0;
      int d= Serial.read();
            if ( d == 10 )
              digitalWrite(ledPin, HIGH);
              digitalWrite(ledPin2, HIGH);
            else if ( d == 20 )
              digitalWrite(ledPin, LOW);
              digitalWrite(ledPin2, LOW);
I simply plugg the Arduino into my computer, open the serial monitor and put "1" into the send text field and send it. RX LED on the Arduino flashes when I do this, but the LED does not go on. Anybody know what im doing wrong here?
Grumpy_Mike
The serial monitor sends code in ASCII, so when you type 1 it actually sends a value of 49.
Look at the example in the arduino IDE for this under serial communication.
