Topic: code switch between ARDUINO 1.0.5 and Arduino 1.5.x (Read 978 times) previous topic - next topic
chenlawrence
Hello all,
          I have one simple question here: is it possible to have same code compiler and debug without any modification by these two software environment. I just tried the example from Arduino 1.5.2, there are errors showed the avr/xx.h missing or not found.
         Is there any solution to fix this and switch between these environment with easy way? Thank you!
chenlawrence
Maybe I'm not clear enough about the problem. I have old lib made with avr library, like io/eeprom... When I reuse these code and lib to 1.5.2. There will be error showed
..\arduino-1.5.2-windows\arduino-1.5.2\libraries\EEPROM\EEPROM.cpp:24: fatal error: avr/eeprom.h: No such file or directory
compilation terminated.
Is that mean, I have to update each lib file by using sam chip?
