Topic: code with zoetrope with stepper (Read 4533 times) previous topic - next topic
treebykooba
hello,
i posted about this earlier and have gotten a little further along.
basically, i have a 3D print of 15 different guys in different positions walking. I am spinning them around in a 2way mirror box with an array of LEDs flashing. I am using a bi polar stepper motor with this configuration: http://arduino.cc/en/uploads/Tutorial/bipolar_schem.jpeg but I'm using the accelStepper library instead of the arduino stepper library.
this is my first time using a stepper so i'm very much in the dark with how to control it.
the problem is, is that i can't seem to time the motor RPM and the LED flashing perfect enough to get anything other than a blur.
what would be ideal is if I can know the exact RPM of the stepper. I have the speed set to 600. Can I assume this is 60 RPM? how would I know?
why do i need to set a max speed with the motor for it to work?
the reason i want to know the exact RPM is because, since i have 15 different positions to animate, i assume if i flash the LEDs 15 times per rotation i will get a zoetrope effect.
any ideas? thanks so much for any guidance!
#include <AccelStepper.h>
AccelStepper stepper; // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3, 4, 5, i changed to 8,9,10,11
const int ledPin =  13;
int ledState = LOW;
long previousMillis = 0;
long interval = 25;
    pinMode(ledPin, OUTPUT);
   stepper.setMaxSpeed(1000);  //why do i need to set this?
   stepper.setSpeed(600);  //is this at 60RPM?
//run stepper
   stepper.runSpeed();
//blink LEDs
  unsigned long currentMillis = millis();
  if(currentMillis - previousMillis > interval) {
    previousMillis = currentMillis;
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    digitalWrite(ledPin, ledState);
holmes4
Maybe you should try thinking in terms of the number of steps per rotation and then flash the leds when thinks are in the right position.
But in a case like this I'd look at how steppers are really controlled and write my own control code. So that you can insert the code to flash the leds in to the stepper control code.
Mark
treebykooba
thanks so much for the help.
where is a good place to start where i could learn how to write my own stepper code? everything out there that i've found i don't understand because i just simply want to control RPM. would an easy driver from sparkfun help? or you think it's better to use this h-bridge?
how do i find out how many steps per rotation i have?
i can't find the datasheet to my stepper anywhere. it's a moons stepping motor 17HD4063-01N, bipolar, the regular 40mmx40mm ones if that helps at all...4 wires.
thank for any more feedback!
holmes4
I don't think this is a hardware issue so stick with what you have.
Use Google your looking for the basics of driving the motor without using a lib. But the code from one of the libs can of course be modified!
Mark
teuchter
Looks like it could be a 1.8 degree stepper, so 200 pulses per rotation. (page 29 of their catalogue for 17HD albeit not your specific code). A 3.6 degree stepper would only require 100 pulses per revolution ie twice as fast.
The stepper motor speed is controlled by the rate of pulses as applied to the stator.
You could even try using a variable controlled via a pot on an analogue input and use this to control the speed rather than having a set 600.
Henry_Best
I suspect that speed() is the number of steps per second, so 600 would give you either 180 or 360 RPM, depending on your motor type.
To check, try setting the speed to a low figure (say 10) and timing one complete revolution.
10 steps/second on a 1.8 degree stepper will take 20 seconds for a complete rev. On a 3.6 degree stepper it will take 10 seconds.
Once you know how many steps are needed for a complete revolution, divide that figure by 15 to tell you how many steps are needed between each flash of your LEDs. If, as I suspect, that figure isn't a whole number (100/15 = 6.666) you'll have to juggle the number of steps between each flash to average out the decimal part (for 6.666 use 7 steps, 6 steps and 7 steps). Once you can do that, the RPM can be set to whatever speed you like without affecting the timing.
treebykooba
thanks so much! this is all super helpful! so yes, it was 20 seconds to rotate at 10 steps per second. so it's a 1.8 degree at 200 pulses a second.
i have other questions now
when i set the stepper.setSpeed(); to too low of a number (below 500 or so), the motor is very jumpy and sort of makes noises and has almost no torque. why is this? i'm just using an h-bridge, would an EasyDriver or something like that help this? do motor drivers help because they do microstepping, thus making the motor rotate smoother?
if i make the flash into the steps does this mean i have to do this in the stepper library? or just write my own code? is there anywhere you recommend where i could learn to write code for a stepper? everything i've found through google is so so confusing and more for robots/printers and not just setting smooth rotations.
thanks again!
laadams85
This should be a very easy modification to using the AccelStepper Library.  You can see what the library is doing here
https://github.com/adafruit/AccelStepper/blob/master/AccelStepper.cpp
So taking a look at the runspeed method, the code there is very similar to what you are doing in your loop function.  So what you can do is take that bit of code and add it to what you are doing
int ledState = LOW;
long previousLedMillis = 0;
long previousStepperMillis = 0;
long ledInterval = 25;
long stepperInterval = 5; // I think this is 60 rpm
long currentPos = 0;
   stepper.setSpeed(600);  //is this at 60RPM?  No it's 600 RPM
  // You could just step 5 times for every led interval, this is more flexible however
  if(currentMillis - previousLedMillis > ledInterval) {
    previousLedMillis = currentMillis;
    if (ledState == LOW){
      ledState = HIGH;
    }else{
      ledState = LOW;
  if(currentMillis - previousStepperMillis > stepperInterval){
previousStepperMillis = currentMillis;
currentPos += 1; //assumes clockwise stepping
step(currentPos & 0x3);
treebykooba
#8
Jun 05, 2013, 05:56 pm Last Edit: Jun 05, 2013, 06:06 pm by treebykooba Reason: 1
thanks so much for the code.
unfortunately my motor was all over the place. it didn't do a full rotation, it was super jerkey and kind of went back and forth. would a driver other than just an h-bridge chip help? or any other ideas?
after running the code for a little bit something popped!! what could it have been? powering this with a 12V 5amp supply...i think it was the h-bridge chip because when i give power to the stepper it budges and has torque...man...
here is the exact code i had:
#include <Stepper.h>
#define STEPS 200
Stepper stepper(STEPS, 8, 9, 10, 11);
int ledState = LOW;
     ledState = HIGH;
   }else{
     ledState = LOW;
stepper.step(currentPos & 0x3);
laadams85
Just try it with only the stepper motor, and take out the bitwise operator, maybe up the interval a bit.  Also you switched stepper libraries, not sure how that would effect things.
#define STEPS 200
int ledState = LOW;
long stepperInterval = 500;
int currentPos = 0;
stepper.step(currentPos);
treebykooba
thanks so much. but why would the above code have fried my h-bridge chip? now i have to wait to get new parts in the mail to test out the rest of the code.
here was how i had it wired up: http://arduino.cc/en/uploads/Tutorial/bipolar_schem.jpeg
i'll report back when the stuff comes in
thanks
laadams85
You can also change the step line to just stepper.step(1); and remove all the currentPos code.
laadams85
I would imagine that the h-bridge chip that you have avoids issues with short circuits, but the classic h-bridge can run into trouble when improper signals are sent to it.
treebykooba
oh wow i found this: https://github.com/xtremd/Zoetrope
for anyone curious. i'm waiting for my easyDriver to come in the mail then i'll try it out.
thanks so much for all the comments.
