Loading...
Pages: [1] 2 3 ... 33   Go Down
Author Topic: Feeling interest for a WiFi shield  (Read 10057 times)
San Jose, CA USA
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Hi all,
I'm currently in the process of doing some marketing research on the viability of a 802.11b WiFi Arduino shield.  It would be a plug-n-play solution to an Arduino Duemilanove or Diecimila.  I'm trying to get feedback and gauge interest in such a part, so any help would be greatly appreciated!
I currently have a working prototype shield that employs 802.11b, up to 2 mbps, works in both infrastructure and adhoc mode, and has a relatively decent range without the need for an external whip antenna.  A lot of work has gone into the wireless module to make it low power, so it would be a great fit to a battery powered Arduino project.
There would be some caveats to using the shield and driver code as-is in the beginning, however.  First off, anything less than an ATMEGA168 (16K flash, 1K SRAM) unfortunately won't cut it due to the size of the driver and small TCP/IP stack sitting on top.  We are projecting about 5-6K or space for user code in the ATMEGA168.  We might be able to shoehorn it into a smaller device, but it wouldn't leave much room, if any, for user content.  ATMEGA328s would be ideal due to the doubling of space.  Packets would also need to be fairly small due to the restriction of SRAM space.  We think you should still be able to do small things like blink remote leds, get temperature sensor readings and the like, but you definitely won't be able to stream 720p video content (maybe in the next revision! smiley ).  I've been told by my WiFi module supplier that things will be changing later this year to remove the "small" packet requirement.  When this happens, we expect to be able to move full-sized packets over the air.
Initially, we are hoping to sell the WiFi shield in the range of $50-$80, intermixed with all the ZigBee and Bluetooth modules that are out there.  The price really depends on you!  If there is enough interest, even with the caveats I mentioned, it would help me tremendously to put pressure on my supplier to give me better pricing.
So please let me know if you are interested, and give me any feedback you may have.  If there are any questions, I'll try and answer those as best I can in this thread.  If all goes well, I'm hoping to have a solution in the market sometime in April.
Thanks!
AsyncLabs
« Last Edit: February 27, 2009, 02:29:19 am by asynclabs » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
wow... that's exciting. I was asking this couple days back!
will it be a stand alone web server type, like the ethernet
shield? the shield is using UART to talk to arduino? thanks.
Logged
London
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
Id love to see something like this.
The only problem I could see would be security.
If I was to hook it into my own home network alongside the family pc's and server Id have to expect it to support full wpa security. Or it wouldnt be able to get on my network. To lower my security would be a bad idea.
If I was to have an application that didnt require internet access and was just a closed loop you could get away with no security but theres still the risk of malicious access.
Would it be possible to implement full security in the space available on say a 328p?
and maybe have a light library without security?
Gordon
« Last Edit: February 27, 2009, 06:10:36 am by GordonEndersby » Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
I would be interested if it cots less than this one
http://www.sparkfun.com/commerce/product_info.php?products_id=8869 and does more smiley
My only requirements would be to talk serial, to support encryption and to be plugable into arduino (a shield basically).
Logged
San Jose, CA USA
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Here are some answers:
The shield will support security (WEP, WPA, WPA2) with both TKIP and AES.  This will be implemented on the ATMEGA168, so there shouldn't be too much concern there.  We are very close to getting everything to work in the 168 (with just the limitation of small packets).  The 328 merely opens us up to larger packets.  Basically, all the existing Arduinos out there should be able to get secure WiFi access with what they have, and they'll be able to transmit larger packets if they choose to upgrade to a 328 chip.
This will be a full Arduino shield, with the same form factor as the Arduino board.  Basically you'll just plug it in on top like any other shield.  It should be a plug n play solution (no having to make special connectors or do any additional wire making).
The shield talks SPI to the Arduino (pins 13,12,11,10) and uses INT0 for interrupt processing.  The shield will also have a reset pin brought up to make it easier to reset the system.  I'll try and take a picture of my early engineering prototype and post it later.
From looking at the datasheet for the WiFly module, I think we'll be able to go toe-to-toe with it.  Smiley  I believe that our big selling point is that we are going to be a shield, with all the correct dimensions to just plug in right away.  It looks like you'll still need to do some work to get the WiFly going (not hard for most guys, but still something that needs to be done).
Thanks for the interest!
AsyncLabs
Logged
London
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
Getting the security sorted is impressive.
Wont the keys take up a lot of ram?
Ill have one to play with.
I was looking at the wall wart type network adaptors that run through the mains electricity supply. when I saw how much a repeater or wireless access point would cost.
Your price range seems to be on a par with them.
Will you be shipping to the UK?
Gordon
Logged
SF Bay Area
Offline Offline
Edison Member
Arduino Ninja
View Profile
WWW
I'm about halfway done with a Matchport Shield, so that'll be one more option available.
Logged
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
0
Offline Offline
Newbie
Arduino rocks
View Profile
I have a working prototype of a shield for the ConnectOne iWifi. Similar to MatchPort and WiFly modules, it does WEP, WPA, SMTP, HTTP, DHCP, etc. etc. Has a small web server on board, and a "SerialNET" mode which just forwards serial data to TCP. $60 from Mouser, but you'd have to make the shield yourself from an Eagle file and several SMD components.
Logged
San Jose, CA USA
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
The host driver actually will only store the keys.  There is a supplicant on the module which will take care of the security.
Logged
SF Bay Area
Offline Offline
Edison Member
Arduino Ninja
View Profile
WWW
It's good to see that options are popping up (even though one of them is by me!). I needed a Wifi shield a while ago and was honestly surprised that it didn't exist.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I am thinking add wifi to homeeasy remote controls...
I want one when it is available. please keep us updated.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Sign me up also as someone who's interested.
Here's my wish list:
  - wpa etc.. as others have said this is a requirement for most networks
  - TCP/IP software interface.. Ideally something that just extends the existing Ethernet software interface.  Basically if I can open a port and send things down and read them serially then I am a happy camper.
  - ability to hard reset (or turn off entirely) the device via a digital pin.  I think the vast majority of projects don't need a constantly on connection, rather they either poll now and then or even more often only make a request when something changes.  Having the board be off during those idle periods would be nice from a power point of view.  Also, being able to do a hard reset is always handy.
  - cost.  If you are talking ~$50 then sign me up, that's an awesome price point.  Definitely can't be over $100.
  - obviously shield format is always nice.
  - 802.11g would be REALLY nice, since the entire network has to back down to b once a b device connects, and most people have g in their homes these days.  I could be ok not having this if we have the ability to turn it off when its not actively sending.
That's my list, looking forward to it!
Logged
San Jose, CA USA
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Sorry I haven't been on the thread in a while.  It was a busy weekend! smiley Thanks for all the great input.  Here are some thoughts I have on what my solution will have:
- definitely support for wep and wpa encryption, so it should work seamlessly on all existing networks
- we will definitely have some type of ethernet interface.  We are putting some more thought into making the interface as easy as possible.
- hard reset via a push button will be on the shield.  This will reset both the arduino and the wifi shield.  Alternatively there will be a method exposed that will do a shield reset from code.
- we have a couple of power savings techniques in mind.  We can probably support low power polling and a form of standby/disconnect for times you want to maximize battery longevity.
- price will definitely be closer to $50 than $100.  I'm trying my hardest to work my suppliers down, and hope that we'll be at the very bottom of the $50-$100 range. smiley
- definitely will be a true shield, with the same form factor (even the fancy cuts on the side opposite the USB port).  Our shield will only cover the pin portion of the arduino.
- for now, it'll be b only.  I don't have the power to change that.  From a compatibility standpoint, I can see the concern of having to mix b and g together on the network.  However, from a pure data standpoint, most applications of our shield won't come near the maximum throughput of even b, so there shouldn't be any concern regarding performance.
This is a rough idea of what is coming down the pipe.
Note that this is not final and is actually our engineering prototype.  Things will be slightly different on our first production board.  We are hoping to make a small run of these boards, get them out to people, get good feedback, and make the next revision of the board even better.
I hope to have a video up in a few days showing a demo of at least a simple web page being served that can trigger some leds to turn on and off.  We have some other interesting demos we are working on as well, so you can stay tuned for that.  8-)
Thanks for all the help and feedback!
AsyncLabs
Logged
London
Offline Offline
Sr. Member
Arduino rocks
View Profile
WWW
Nice work.
Will you be extending the pins through to female on top so shields can be stacked?
Gordon
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
good job.  Do you have a website or email list that I can pre-order
or get notified when it is available? thank you.
Logged
Pages: [1] 2 3 ... 33   Go Up
Print
Jump to:
