Topic: Feeling interest for a WiFi shield (Read 71279 times) previous topic - next topic
Pauly
This is awesome.  My order is placed.
I haven't done much experience with data like this.
Any more examples would be very helpful.
For instance, in the example you give, how do we know what the web address is of the page it puts up, is is the IP address of 192 168.1.2?
If so how do we access that?
Thanks again
asynclabs
I'll try my best to provide as much help and documentation as possible.
For the example webserver, the arduino will connect to your access point with the SSID name (default is "ASYNCLABS") at the address 192.168.1.2.  So if you have another PC/laptop connected to this access point, then you could visit 192.168.1.2 in your webbrowser to see the simple webpage.
You can also open a terminal and send simple ping commands to the device, and it should respond back that it's alive, i.e.:
C:\> ping 192.168.1.2
This side project/hobby/business is quickly becoming a lot more work that I originally planned.  I see lots of late nights in my immediate future.  haha  ;D
TeamMCS
Ha, I'm sure the community will help you out as soon as they arrive. Throw in a discount and they may be even more helpful :P
I'm rather looking forward to the evil cunning things I can do with this
SteelToad
I received mine today. Nicely put together.  I've got some questions on the webserver sketch, but I'll wait till I've played with it some more to make sure it's just not my silly noob mistakes (likely). It's alive, and I can ping it though.
What does the red led indicate, and what is the button for (reset?)
Pauly
The example sketch loads fine and the red light is on, but I cannot ping it (192.168.1.2) or access the web page.  Any suggestions for a noob on a MAC?
John_Ryan
@pauly. open system preferences, click on network .. whats your machines IP address?
Pauly
John_Ryan
Our mac's are addressed 10.1.1.1 upward so that means we'll be changing
unsigned long local_ip = IP_ADDR(192,168,1,2);
to
unsigned long local_ip = IP_ADDR(10,1,1,99);
I asked on the "off chance" yours was the same.
I checked the library and IP_ADDR appears to be the only pointer to IP address, so I'm assuming its ok to change in WebServer.pde
estranged
Got mine in today.  Pretty easy setup.  I was able to connect to my WPA Personal network, and I can ping it.  I can see the request come in through the serial debug connection in the Arduino IDE, but I'm getting inconsistent results in browsers.  Firefox sometimes displays the resulting page, and sometimes not.  Safari doesn't.  Its almost like the request isn't being finished off somehow, and is just left spinning.  Will continue to play with it.  As far as I can tell, the red light comes on when the shield is successfully connected to the network.
All in all, very impressed with the 'out of the bag' experience.  Good job. :D
SteelToad
If you turn on or off the serial monitor in the Ardunio IDE, does your light go out ?
I've been having problems testing with Firefox, but I used a port tester I wrote a while ago and if I send it just "GET / HTTP/1.1" followed by a CR+LF I get a response every time. Its strange, but I'm still tinkering.
asynclabs
Ok, I have some bug fixes that hopefully will fix some of the issues people might be seeing.  Part of the problem also seems to be that in some cases, multiple requests are coming in, which is somehow confusing the code.
The red light is supposed to come on when connected to the network.
Let me get the code packaged up and ready for consumption.
estranged
I think this is correct.  Most browsers seem to ask for / and /favicon.ico in quick succession.  The first request seems to work correctly, and returns the page.  The second request seems to mess it up, and no future requests seem to work.  Resetting the arduino allows me to start over, but again only getting the first request properly.
asynclabs
Do you have security enabled?  Oddly, the setup I use most of the time doesn't have security on, and seems to work more solidly.  It's strange...
estranged
I have WPA Personal security turned on, and a MAC address filter.  I will have to wait for the wife to finish with some stuff before she will let me start tinkering with the network settings.  She hates it when I 'fix' things.
asynclabs
Ok, I put new code drops up on our wiki.  This still might not fix the multiple request problem, but at least we can all rebase on a common image.
Sorry about all the issues in the stack.  I've enlisted additional help on my side to try and resolve the issue.
