Topic: Digital write not working on DUE but same code works Uno and Mega 2560 (Read 765 times) previous topic - next topic
konasilly
The following code works great on UNO and Mega 2560.  It is a driver for an Elechous dual channel motor driver.  I am using it to drive linear actuators with a joystick.  the condition loops work but digital write pins do go high when required.  see asterisks in code. Any help would be much appreciated
Quote
int SignalA= (0);//define input signal pin
int SignalB= (0);//define input signal pin
  pinMode(2,OUTPUT);
  pinMode(3,OUTPUT);
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(9,OUTPUT);
  // default mode is INPUT
void LaIn()// Linear Actuator A IN
  digitalWrite(2, HIGH);   // in
  digitalWrite(5, HIGH);   // in
  analogWrite(3,1);   // in
void LaOut()// Linear Actuator A Out
  digitalWrite(2, HIGH);   // out
  digitalWrite(3, HIGH);   // out
  analogWrite(5,1);   // out
void LaStop()// Linear Actuator A STOP
  digitalWrite(2, HIGH);   // stop  *********this pin goes high**********************
  digitalWrite(3, HIGH);   // stop  [font=Verdana]********************this pin and pin 5 do not ******************[/font]
  digitalWrite(5, HIGH);   // stop
  Serial.print("hello");
  Serial.print("\t");
void LbIn()// Linear Actuator B IN
  digitalWrite(8, HIGH);   // in
  digitalWrite(6, HIGH);   // in
  analogWrite(9,1);   // in
void LbOut()// Linear Actuator B Out
  digitalWrite(9, HIGH);   // in
  analogWrite(6,1);   // in
void LbStop()// Linear Actuator B STOP
  digitalWrite(8, HIGH);   // stop
  digitalWrite(9, HIGH);   // stop
  digitalWrite(6, HIGH);   // stop
void loop()  {
  digitalWrite(0, LOW);
  digitalWrite(4, LOW);   //  set pin low
  digitalWrite(7, LOW);   //
  SignalA=(analogRead(A0));
  SignalB=(analogRead(A5));
  Serial.print(SignalA);
  Serial.print("\t");
  Serial.print(SignalB);
  Serial.print("\t");
  Serial.println(" ");
  if (SignalA > 900)
    LaIn();
  if (SignalB > 900)
    LbIn();
  if (SignalA < 400)
    LaOut();
  if (SignalB < 400)
    LbOut();
  if (SignalA > 400 && SignalA < 900)
    LaStop();
  if (SignalB > 400 && SignalB < 900)
    LbStop();
  delay(10);
