Topic: PWM problems with Arduino Due? (Read 994 times) previous topic - next topic
Persuader
Jun 08, 2013, 06:47 pm Last Edit: Jun 08, 2013, 07:15 pm by Persuader Reason: 1
Hey guys, I recently got my hands on an Arduino Due and I'm trying to familiarize myself with the various functions and the programming.
Now, the pins 2-13 are supposed to have PWM so I tried fading-in/out LEDs from these pins. I cannot use PWM with pins 6-7, but I can use the digitalWrite to blink the LEDs in those pins.
This is the code I am running:
Code: [Select]
int j;
int del=2;
int k=1;
  pinMode(k, OUTPUT);
  for(j=0; j<=256; j++)
    analogWrite(k, j);
    delay(del);
  for(j=256; j>=0; j--)
    analogWrite(k, j);
    delay(del);
Am I doing something wrong? Is it possible that the board is defective?  Or perhaps that I've managed to somehow damage it?
Paul F.
Persuader
Ah, yes, indeed I manually changed the code to all the numbers from 2-13 manually to see which of the pins where not working.
I actually discovered the issue when I tried to fade in/out LED from pins 13-5 with a for loop, then I noticed that the loop stuck at  LED7 every time, I then removed the for and changed variable k manually.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
