Topic: error expected initializer at end of input (Read 5533 times) previous topic - next topic
Jun 09, 2013, 09:01 pm Last Edit: Jun 09, 2013, 09:04 pm by meths87 Reason: 1
Hi there, I'm reasonably new to using Arduino and am trying to communicate using two Arduino's and an RF 433mhz Tx and Rx. I got this code off of http://forum.arduino.cc/index.php?topic=160262.0 just to do simple communication but am getting an error message on the receiver
I have been trying to get past this for a couple of days and have tried all the things suggested related to this error message like adding a semi-colon or using {} but no success.
I eventually want to move a servo with potentiometer like the knob example on the programmer but through wireless.
Any help with this code or the any code to achieve my goal would be greatly appreciated.
have been looking for code to do this for weeks but havent found anything simple enough to play around with, say add a few more pots and servos.
Anyway any help would be appreciated.
//Receiver Code
//Receiver Code
#include <Servo.h>
Servo myservo;            // Create servo object to control a servo
char readstr[4];          // Character Array to store the serial input
int cstrpos = 0;          // Variable to store current input array position
long val = 0;             // variable to store the value from the input
int maxValue = 175;
 Serial.begin(9600);     // Startup the Serial Interface
 myservo.attach(9);      // Attaches the servo on pin 9 to the servo object
Your "loop" is missing a pair of braces.
Curly or normal?
Thanks for the help. I know a loop is probably quite basic and im being a noob but the programming is a small part of the project and didnt expect it to be quite this difficult to find a code from someone trying to do something dimilar.
Again thanks for your time.
Usually, you'll hear programmers use the following:
{ -- Opening brace
} -- Closing brace
( -- Opening parenthesis
) -- Closing parenthesis
[ -- Opening bracket
] -- Closing bracket
In general,
   braces mark statement blocks (e.g., the start and end of a function block, start and end of an if statement block, loop structures)
   parentheses delineate parameter lists (e.g., arguments passed to functions) or are used to force the order in which an expression is evaluated (e.g., Y * (X + 2))
   brackets defines array size and rank
