Topic: SipHash, cryptographic hash library now available for Arduino (8bit) (Read 5023 times) previous topic - next topic
drmpf
I have finished a streaming SipHash library for Arduino.
It is available here (http://www.forward.com.au/pfod/SipHashLibrary/index.html)
From the https://131002.net/siphash/  page
Quote
SipHash is a family of pseudorandom functions (a.k.a. keyed hash functions) optimized for speed on short messages
SipHash is secure, fast, and simple (for real):
SipHash is simpler and faster than previous cryptographic algorithms (e.g. MACs based on universal hashing)
SipHash is competitive in performance with insecure non-cryptographic algorithms (e.g. MurmurHash)
The library is small (~1200 bytes code and 42byte RAM) and fast and uses 128bit secret keys.
I will be using it to provide a per message MAC (http://en.wikipedia.org/wiki/Message_authentication_code) for authentication and verification of pfod (www.pfod.com.au) messages to provide security against hackers taking control of my pfodDevice when I am accessing it over the internet.
See http://www.forward.com.au/pfod/secureChallengeResponse/index.html for the detailed design of the message security.
matthew
pito
#1
Jun 09, 2013, 11:17 pm Last Edit: Jun 09, 2013, 11:25 pm by pito Reason: 1
Does the key use only lower nibbles? Can I use higher nibble as well?
How long the message can be?
drmpf
The key is 128bits  i.e. 16 bytes,  all bits are used. Upper and lower nibbles in each byte are used.
For security this key MUST BE RANDOM.  See the "Generating the Password" section towards the bottom of http://www.forward.com.au/pfod/secureChallengeResponse/index.html for a method of getting 'random' keys
The message size in unlimited (by the SipHash)
you call SipHash.updateHash((byte)c);  for each byte in the message.
SipHash internally accumulates 8 bytes and then adds them to the hash and then discards them.
In finalize() SipHash adds the msg length % 256.  The code assigns one byte to keep this value and updates it each time updateHash() is called.
sample usage
// Define your 'secret' 16 byte key in program memory (flash memory)
unsigned char key[] PROGMEM = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07,
                               0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f};
// to start hashing initialize with your key
SipHash.init(key);
// for each byte in the message call updateHash()
for (int i=0; i<msgLen;i++) {
   SipHash.updateHash((byte)c); // update hash with each byte of msg
// at the end of the message call finalize to calculate the result
SipHash.finalize(); // finish
// the unsigned char[8] variable, SipHash.result, then contains the 8 bytes of the hash in BigEndian format
pito
#3
Jun 10, 2013, 12:07 am Last Edit: Jun 10, 2013, 12:08 am by pito Reason: 1
So it does not encrypt the message, just creates a hash, so when I send a message to my second arduino (B), the B creates the hash (based on the same secret key I have got) upon the message, the B sends me the hash back, and I may compare the B-hash with my hash I did for the same message before. When my compare of both hashes match, I know a) the B is my friend, b) the message has not been altered by somebody during the transport to the B. Is my understanding correct please?
drmpf
Correct, the message is not encrypted (hidden).
BUT the hash lets you check
i) that the other party has the same secret key
ii) that the message has not be modified by some third party.
There are a few more details that need to be attended to
See http://www.forward.com.au/pfod/secureChallengeResponse/index.html for the detailed security design based on this (or some other) secure hash.
matthew
pito
That could be used with optiboot when doing remote upload:
a) it confirms I did the upload to the proper device,
b) that nobody modified my sketch,
c) that upload has has been received properly..
westfw
Quote
Hmm.  "Could be used with a bootloader", I guess.  Adding 800+ bytes of crypto code to a 500 byte bootloader would sort of do away with the "opti" designation.
drmpf
Just checked the latest SipHash code and it appears to add about 1200 bytes in its current form (the 800 came from an eariler AVR studio code set)
drmpf
Have updated the library to allow initialization from either a key in RAM or in PROGMEM
pito
Quote
Adding 1200bytes to a "standard bootloader" will do it a "gigauploader". So adding it to the optiboot it will still be "opti" :)
westfw
Quote
Really?  50% code growth going from AVR Studio to Arduino?  What happened?
drmpf
rechecked the C code got
            Program Memory Usage    :   1032 bytes   12.6 % Full
            Data Memory Usage       :   44 bytes   8.6 % Full
found note that size was previously 920 so no idea what I was thinking when I wrote 800
drmpf
I have added a Java version also here
http://www.forward.com.au/pfod/SipHashJavaLibrary/index.html
This Java version differs from the existing Java implementations in two ways
i) It gives the correct result for bytes whose leading bit is set (128-255)
ii) and is a streaming implementation
matthew
