Topic: Control cheap RC toy car RX2 chip with Arduino using only one pin - [SOLVED] (Read 12378 times) previous topic - next topic
mindprobe
Hi everyone,
I bought a cheap Chinese toy car and it has the famous TX2/RX2 chip combo. What I would like to do is get rid off the TX2 transmitter (the remote) and control the RX2 chip in the car with an Arduino.
I know the easiest solution is to simply hook up the Arduino to the RX2 H-Bridge pins and write HIGH, LOW to control the driving and steering movements as explained in this tutorial (http://letsmakerobots.com/node/31757). This is OK, but I want to be able to generate the same pulse signals the TX2 transmitter (remote) is sending to the RX2 (car) receiver directly with the Arduino. The RX2 has a signal input pin (Pin 3 usually on RX2 chips). With the right programming it should be possible to PWM the right combination of pulses from the Arduino to that signal input pin of the RX2 chip to signal movements like forward, backwards, etc.
I have a datasheet here for the RealTek RX2/TX2 chip. On page 4 you can see the data format (pulse signals) the RX2 chip understands.
http://www.jbprojects.net/projects/wifirobot/TX2RX2.doc
W2 W2 W2 W2 (n) x W1 W2 W2 W2 W2 (n) x W1 W2 W2 W2 W2
Number of Function Codes (n) W1 | Function Key
4      End Code
10   Forward
16   Forward & Turbo
22   Turbo
28   Turbo & Forward & Left
34   Turbo & Forward & Right
40   Backward
46   Backward & Right
52   Backward & Left
58   Left
64   Right
The W2 are 500 Hz at 75% duty cycle
The W1 are 1KHz at 50% duty cycle.
The W1 pulses are the function code, so for example 10 W1 pulses will cause a forward movement, 58 W1 pulses activate left steering. The W2 pulses seem to be Start and End commands before and after the W1 pulses.
Has anyone ever done something like this? If not, wouldn't it be cool to figure this out and get it documented? Think about it, this method would allow Arduino to RC car communication using only one pin from the Arduino going to a single signal input pin on the RX2 receiver chip. No need to hook up 4 to 5 pins from the Arduino to the RX2 H-Bridge's forward, backward, left, right, turbo pins to control movements.
This would be a fun project and only requires a $5 US cheap Chinese toy car you can find in any store.
Who is up for the challenge?  8)
mindprobe
#1
Jun 10, 2013, 03:38 pm Last Edit: Jun 10, 2013, 03:47 pm by mindprobe Reason: 1
After doing some research, it seems Bit-banging Pulse Width Modulation, which apparently allows full control of the duty cycle and frequency, might be a possible way to send a proper signal from the Arduino to the RX2's signal encoder input pin. More ways to send a custom PWM signal are described here (http://arduino.cc/en/Tutorial/SecretsOfArduinoPWM). They are Fast PWM and Phase-Correct PWM.
Does anyone have some ideas how to approach this?
mindprobe
#2
Jun 11, 2013, 06:13 pm Last Edit: Jun 11, 2013, 06:34 pm by mindprobe Reason: 1
I managed to connect a small speaker to the TX2 car remote chip SO pin 8 and now I can hear the different PWM pulse signals the buttons forward, reverse, left and right generate. Pretty cool!  :smiley-surprise: The signal has rougly 1.3 volts when I measure it with a multimeter. I have tried to generate these PWM pulses for the FORWARD command with the Arduino using Bit-banging and when I hook up a speaker to the Arduino, the signals sound identical to TX2 remote signal sounds. With some luck, this generated pulse signal from the Arduino will be understandable by the RX2 in the car and make it controllable. First I will try to connect the TX2 signal output pin 8 directly to the RX2 signal input pin 3. The datasheet of the TX2/RX2 chip has an example testing circuit that does the same, so it should work.
I will keep you guys updated on the progess!
PeterH
You seem to have presented the problem and identified a viable solution. It seems like a pretty obscure problem so not too surprising that you're the first to tackle it. Why don't you just go ahead and implement your solution?
mindprobe
#4
Jun 11, 2013, 06:28 pm Last Edit: Jun 11, 2013, 06:36 pm by mindprobe Reason: 1
The question is, would the Arduino be able to generate the right PWM pulses at the right frequency, speed, stable and at the right voltage and current? I noticed the Arduino PWM signal has 2.6 volts which is twice as much as the signal measured on the TX2 remote (1.3 volts). Is it possible to change the voltage of the signal coming from the Arduino from 2.6 to 1.3 volts using a transistor voltage divider with two transistors of 1Kohm in series or does it not matter what voltage the signal from the Arduino has?
I read something about disabling interrupts, but I don't know what that is or what the difference to bit-banging is. Maybe it's not even needed. Anyone have an idea?
PeterH
The Arduino outputs are either 5V or 0V depending whether they're set high or low.
If you need less than 5V you can reduce the voltage using a pair of resistors as a voltage divider.
I don't see any reason why you couldn't generate your output signal entirely in software, using millis() and micros() to determine when the next change is due. I haven't bothered looking at the details of the encoding scheme you describes, but if it's just a digital signal at less than 5V and the highest frequency is only around 1KHz then I don't see any reason why it wouldn't work.
mindprobe
I have been able to connect the TX2 pin 8 directly with the RX2 pin 3 to send a communication signal bypassing the antenna completely!  :smiley-surprise:
Now I will try to send the Arduino generated pulse signal to the RX2.
mindprobe
#7
Jun 11, 2013, 08:52 pm Last Edit: Jun 11, 2013, 09:28 pm by mindprobe Reason: 1
I got it working!!!  8)
I can now control the RC car's RX2 receiver chip with just one single pin from the Arduino using pulse signals the RX2 chip can decode and understand. I can fully control the movements of the car. It works absolutely perfect. No need to hook up multiple wires to your RC car robot anymore and no need for the TX2 remote at all. A dream come true. I hope this will bring joy to many people.
Here is the Arduino sketch code:
Code: [Select]
 pinMode(11, OUTPUT);
 for(int i=0; i<=3; i++) // This starts the communication 4 W2 pulses 1KHz 75% duty cycle
   digitalWrite(11, HIGH);
   delayMicroseconds(1500);
   digitalWrite(11, LOW);
   delayMicroseconds(500);
 for(int i=0; i<=9; i++) // This makes the car go "forward" 10 W1 pulses 500Mhz 50% duty cycle
Here is a picture of my project:
cr0sh
I have to give a huge "bravo" for this; such a hack makes it much easier to hook up and control these vehicles (though you do lose the ability to PWM the drive motor - but that probably isn't much of a loss).
For those coming here, I want to point them to the "mega-thread" on the TX2/RX2 chipset R/C car modding:
http://forum.arduino.cc/index.php/topic,86883.0.html
I'm also going to post a link from there to here, too - all this so things can stay somewhat "together".
Now all that needs to be done is for someone to make a library (hint, hint)...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
mindprobe
I plan on having the RC car drive at very slow and constant speeds to use it as surveillance bot. Being able to alter the speed and not losing too much torque is required.
Theoretically PWM is still an option. You could simply PWM (delay) the actual pulse signal being send to the RX2 and not even lose any torque on the motor. I will run some tests later today.
monsieurDavid
Thanks mindprobe for posting you code. I had been working on a similar project and solved it using the controller chip hardware registers for PWM timing. I'm a afraid I wouldn't do a good job at explaining in details how the PWM registers code works but Chapter 18 from 'Arduino Cookbook' (O'Reilly) helped a lot there.
I refactored my project using your simpler code and I am very glad to report that it appears that the RX2 chips is more responsive to it.
Anyways, I posted a demo (using the hardware pwm code) of my RX2-based toy being controlled by a few buttons on the Arduino: http://youtu.be/7js6pt2g0ac
The source code for both codes are on github: https://github.com/monsieurDavid/rx2-hacks
Cheers!
hyper_space_lab
Hi, mindprobe!
Thanks for sharing your info.
I tried your sketch on my RC toy, with some modification.
My toy was a Power Shovel with two treads.  So, the RC command was a little irregular.
You can see the demo on YouTube: http://youtu.be/LrjDkY4RnAY
Also, you can visit my Blog here: http://blogs.yahoo.co.jp/ryo_hirayanagi/12113115.html
(Sorry, the Blog is in Japanese.  I think you can figure out what I'm doing from the codes and the pictures.)
Thanks. again!
Isaac96
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
hendryl
Hey, man, are the resistors essential for it to work? I've been trying for quite a while and can't seem to figure it out. The pin10 is connected to the antenna wire and the toy's ground is connected to Arduino's GND.
Am I doing something wrong?
rekkuuza
hyper_space_lab, where could I get one of those clips that you used to connected to the pin of the IC?
