Topic: RTC module not running (Read 821 times) previous topic - next topic
senne
Hello,
I have an RTC module which is integrated in an arduino shield (touchscreen shield) I can set the time and save it , but the time is not running , the problem is not the code because this is the code of someone with which it worked. What connection in the RTC module takes care of running the time?
jackrae
Broken spring  XD XD
Sorry - couldn't help it !
MarkT
You need to program the enable bit in the RTC if you want its clock to run.
senne
But I know the rtc program is good, its an hardware problem . ;)
j514
Is there an on-board 3v battery? If so, try resetting it / replacing it.
a][+ ascii express, 110/300 novation cat, xmodem
senne
No, there is no battery yet, could this be the solution to get my time running?
j514
#6
Jun 12, 2013, 12:07 am Last Edit: Jun 12, 2013, 12:09 am by j514 Reason: 1
Yes that would be it.  For now, put a copper penny in the battery socket and it will work (except you'll lose the time when you turn the power off.)
senne
I did it but it didn't work , the time keeps standing still, any other options?
dannable
In that case it's the old mantra of 'post your code, post a photo / schematic'!
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
