Topic: L298 LAP (Read 2899 times) previous topic - next topic
revolver995
Hi , I'm looking for clarification to use of the L298 in LAP.
i've done this circuit with eagle ,  pwm is on the IN1 and IN2 , and i have connected a digital output on the ENABLE ;
so could you tell me if the schematic is correct ? , and how can i programm the pwm with this configuration ? because when the pwm is 50% the motors should  stop;
Thank you
cr0sh
You might want to define what the acronym "LAP" stands for...?
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
oric_dan
From his ckt and description, LAP apparently means Locked Anti-Phase. Some people
use this, I never have. The motors grind too much, full power all the time, lot of heat.
The schematic appears to be ok, but I don't understand "how can i programm the pwm
with this configuration", as it should be apparent.
revolver995
i mean ,how can i write the code for this configuration ? because i have no idea , i might use AnalogWrite (PIN , 255);
but i'm not sure.
Please help me and thank you
oric_dan
http://arduino.cc/en/Reference/DigitalWrite --> HIGH to the enable pins,
http://arduino.cc/en/Reference/AnalogWrite --> 128 to the 4011s.
128 should set the motors to zero speed. 255 --> full forward, 0 --> full reverse.
revolver995
Are you sure about this tipe of code ? because an italian moderator say me that it doesn't work.
Have you tried this code with this configuration ?
Thank you for the answer
revolver995
Quote
Some people
they told me the exact opposite
oric_dan
Just go on and try it, and see how it works. That's the "proof of the pudding", as they say.
As I mentioned, I haven't done it myself, and I never decide on anything until I've actually
tried it myself.
-Standby
I think i can help you a bit, i am currently working on my bot it's very similar as yours.
Code: [Select]
****** -Standby @Standby_live.fr**************
***************June 2013*********************/
#define buzPin 6
const int enApin = 3, enBpin = 5;
const int in1pin = 2, in2pin = 4;
byte motorSpeed;
  printMenu();
  pinMode(in1pin, OUTPUT);
  pinMode(in2pin, OUTPUT);
  if (Serial.available()) {
    char incomingByte = Serial.read();
  if (isDigit(incomingByte)) {
    motorSpeed = map(incomingByte, 0, 9, 0, 255);
    analogWrite(enApin, motorSpeed-5); // Calibrating motor to drive straight.
    analogWrite(enBpin, motorSpeed);
  switch (incomingByte) {
    case '+':
    bip(50);
    moveForward();
    stopBip();
    case '-':
    bip(50);
    moveBackward();
    stopBip();
void printMenu() {
  Serial.println("Testing H-Bridge with logic gate");
  Serial.println("------ Menu ------");
  Serial.println("Select the speed with 0-9");
  Serial.println("Select the direction with + or -");
******Robot function******
void moveForward() {
  digitalWrite(in1pin, LOW);
  digitalWrite(in2pin, LOW);
void moveBackward() {
  digitalWrite(in1pin, HIGH);
  digitalWrite(in2pin, HIGH);
void moveRight() {
  digitalWrite(enApin, LOW);
void rotateRight() {
void rotateLeft() {
void motorStop() {
  digitalWrite(enBpin, LOW);
*****Buzzer Functions******
void bip(int delayMs) {
  analogWrite(buzPin, 50);
  delay(delayMs);
  digitalWrite(buzPin, LOW);
  delay(delayMs);
void stopBip() {
The Mind is like a parachute it works best when opened.
