Topic: How Can I merge char variable (Read 7419 times) previous topic - next topic
pierrot10
Good evening all,
I need to merge some char into a another.
Here are my declaration
char coords[100];
char lon[15];
char lat[15];
char alt[15];
char time[20];
char vel[15];
At the end, I would like to have this
coords = "lat="+lat+"&long="+lon+"&alt="+alt+"&speed=&course="+val+"&date=2013-04-25&time="+time+";
By the way, the time is returning with in this format
20130615220230.000
How can I get it a human readable?
Cheers
Il ne suffit pas de tout savoir, la persévérance, c'est déjà presque tout!
You can not know everything, perseverance, it is almost everything!
AWOL
pierrot10
I am not sure, if it works
this return me only the time value
strcpy (coords,"lat=");
      strcpy (coords,lat);
      strcpy (coords,"&long=");
      strcpy (coords,lon);
      strcpy (coords,"&alt=");
      strcpy (coords,alt);
      strcpy (coords,"&speed=");
      strcpy (coords,"");
      strcpy (coords,"&course=");
      strcpy (coords,vel);
      strcpy (coords,"&date=");
      strcpy (coords,"2013-06-16");
      strcpy (coords,"&time=");
      strcpy (coords,time);
Serial.println(coords);
j514
#3
Jun 16, 2013, 12:47 am Last Edit: Jun 16, 2013, 12:49 am by j514 Reason: 1
try this:
char coords[50];
snprintf(coords,50,"lat=%s&long=%s&alt=%s&speed=%s&course=%s&date=%s&time=%s",lat,lon,alt,speed,vel,date,time);
edit: variable name
a][+ ascii express, 110/300 novation cat, xmodem
acaine
Or, use the String class with operator+, such as
String message = String("lat") + String(lat)  ...and so on
pierrot10
Si when I uncomment this
char coords[100];
//snprintf(coords,100,"lat=%s&long=%s&alt=%s&speed=%s&course=%s&date=%s&time=%s",lat,lon,alt,"",vel,"2013-06-22",time);
the program free. So stop at the begining
Arrch
pierrot10
The terminal show the progress but it stop at the 5ft line. Nothing happen. When I comment the line, the code/terminal continue in his right process
Arrch
What terminal? What 5ft. line?
pierrot10
This is when is commented
Starting SIM908.
Please wait...
DB:ELSE
DB:ELSE
DB:ELSE
DB:CORRECT BR
Turn on
status=READY
Attaching GSM
DB:ALREADY HAVE AN IP
status=ATTACHED
GSM RAEDY TO GO!
Attaching GPS
status=GPS READY TO GO!
sms => Send SMS
data => Send data to the server
get => Get data from server
gps => Get GPS coords
test => Test system
This is when it uncommented (not good)
Starting SIM908.
Please wait...
DB:ELSE
DB:ELSE
DB:ELSE
DB:CORRECT BR
pierrot10
To resume,
I have this
gps.getPar(lon,lat,alt,time,vel);
and it should be in the coords variable of this
inet.httpPOST(host, port_post, path_post, coords , "Result", 1000);
But I hav to add URL varaiable like this
:smiley-slim: :)
Arrch
And how are we supposed to know what's wrong when you've only posted no more than 4 lines of your code?
j514
char coords[100];
"" is invalid, use a variable.  Here, I've done the work for you.
  char coords[100];
  char lon[15];
  char lat[15];
  char alt[15];
  char vel[15]; // speed
  char crs[15]; // course
  char date[20];
  char time[20];
    // make sure each variable is initialized or sprintf will return junk
    strcpy(lat,"99.9");
    strcpy(lon,"11.1");
    strcpy(alt,"22");
    strcpy(vel,"55mph");
    strcpy(crs,"2.5NE");
    strcpy(time,"21:01:01");
    strcpy(date,"6/15/2013");
    snprintf(coords,100,"lat=%s&long=%s&alt=%s&speed=%s&course=%s&date=%s&time=%s",lat,lon,alt,vel,crs,date,time);
    Serial.end();
void loop() {}
pierrot10
#13
Jun 16, 2013, 07:55 am Last Edit: Jun 16, 2013, 08:24 am by pierrot10 Reason: 1
Hello All
thank for your answers and help, but I am afraid it did not solve my issue.
I am sorry if I have been not clear enough.
Here is a resume
// GPS
char coords[100];
char lon[15];
char lat[15];
char alt[15];
char time[20];
char vel[15];
char msg1[5];
char msg2[5];
This collect the GPS coords
Then from now, I have the longitude (lon) the latitude (lat) etc. No worries for sppeed and course, I will see it later.
I have to send the cords to a remote server and for this I use this function
      delay(10000);
Coords is the char variable which must contain the value.
If I code
coords = "lat="+lat+"&long="+lon+"&alt="+alt+"&vel="+val+"&time="+time;
This works fine, but now I have to replace the "10.000", "20.000" etc by the value provided by the GSP.
So I tryied this
coords = "lat="+lat+"&long=20.0000&alt=30.000&speed=&vel=40.000&time=20130609062400.097;
but this does not work.
I have this error message
Invalid operands of types 'const char[5]' and 'char[15]' to binary 'operator' +
That's it
pierrot10
Ok, I solved my problem this way
      strcat (coords,lat);
      strcat (coords,"&long=");
      strcat (coords,lon);
      strcat (coords,"&alt=");
      strcat (coords,alt);
      strcat (coords,"&vel=");
      strcat (coords,vel);
      strcat (coords,"&time=");
      strcat (coords,time);
Now I have a last question.
time diaply this : 20130609062400.097
how can I have it in a readable format?
many thank
