Topic: How Can I merge char variable (Read 7976 times) previous topic - next topic
Tom Carpenter
#15
Jun 16, 2013, 11:53 am Last Edit: Jun 16, 2013, 12:00 pm by Tom Carpenter Reason: 1
You could try something like this:
strcat (coords,"&yr=");
strncat(coords,time,4); //first 4 chars are year
strcat(coords,"&mon=");
strncat(coords,time+4,2); //next 2 are month
strcat(coords,"&day=");
strncat(coords,time+6,2); //next 2 are day
strcat(coords,"&hr=");
strncat(coords,time+8,2); //next 2 are hour
strcat(coords,"&min=");
strncat(coords,time+10,2); //next 2 are minute
strcat(coords,"&sec=");
strcat(coords,time+12); //remainder is seconds
But there ought to be a better way of doing this. Perhaps if you actually posted your code, then one could be suggested.
Part of the trouble you are having is that your coords[100] buffer is not large enough to store the entire concatenated string. Count how long the string is, trust me, its more than 100 characters.
~Tom~
PaulS
time diaply this : 20130609062400.097
how can I have it in a readable format?
How can you have what in a readable format on what?
You might have better luck with your snippets at http://snippets-r-use.com. Here, we expect (and need) to see ALL of your code. It is possible that you are running out of memory.
pierrot10
Dear Tom Carpenter and Paul
Thank for your answer. Tom I am going to try your proposition and I count the amout of caracters but apparently it should be fine, because here are declare the char variable
char coords[100];
char lon[15];
char lat[15];
char alt[15];
char time[20];
char vel[15];
char msg1[5];
char msg2[5];
@Paul
When I publish that post, I have not niticed the here that number 20130609062400.097
there is year, month etc.
So at the final, I would like to have this in that formatz
2013-06-09 06:24:00
So to be sincerly, I do not know what it's exacetly this 062400.097. I supposed it's the time, but I do not think that at 6am, I was working....  :~
but in order to make sure, I ma going to increate coords to 150
Il ne suffit pas de tout savoir, la persévérance, c'est déjà presque tout!
You can not know everything, perseverance, it is almost everything!
wildbill
It looks like the time as you surmised, with a decimal component to the seconds. As to it not being the time of day you expect, does it make sense if it were Zulu time (GMT) ?
PaulS
Still with the snippets, eh? When you post ALL of your code, we can help.
pierrot10
#20
Jun 17, 2013, 05:21 pm Last Edit: Jun 17, 2013, 05:52 pm by pierrot10 Reason: 1
Dear Paul, It a bit hard becaue it would be really a lot of reading.
The date is generated by a GPS library.
I declare my variabel like this:
#include "gps.h"
GPSGSM gps;
// GPS
char coords[150];
char lon[15];
char lat[15];
char alt[15];
char time[20];
char vel[15];
and here is a function to get the coords
void getGPSfix(){
       Serial.println(F(""));
      Serial.println(F("GPS FIX"));
      Serial.println(F("--------------"));
        delay(5000);
//Get data from GPS
gps.getPar(lon,lat,alt,time,vel);
Serial.print(F("Long :"));
        Serial.println(lon);
        Serial.print(F("Lat :"));
Serial.println(lat);
        Serial.print(F("Alt :"));
Serial.println(alt);
        Serial.print(F("Time :"));
Serial.println(time); // This retunr me something like 20130617062400.345
        Serial.print(F("Vel :"));
Serial.println(vel);
Apparently we have to manager the string, but I do not know exactely how to delimeter the time
@Paul,
Is enoguth for you?
In the gps.cpp file, there is that fonction
char GPSGSM::getPar(char *str_long, char *str_lat, char *str_alt, char *str_time, char *str_speed)
char ret_val=0;
char *p_char;
char *p_char1;
gsm.SimpleWriteln("AT+CGPSINF=0");
gsm.WaitResp(5000, 100, "OK");
if(gsm.IsStringReceived("OK"))
ret_val=1;
//longitude
p_char = strchr((char *)(gsm.comm_buf),',');
p_char1 = p_char+1;  //we are on the first char of longitude
p_char = strchr((char *)(p_char1), ',');
if (p_char != NULL) {
          *p_char = 0;
strcpy(str_long, (char *)(p_char1));
// latitude
p_char++;
p_char1 = strchr((char *)(p_char), ',');
if (p_char1 != NULL) {
          *p_char1 = 0;
strcpy(str_lat, (char *)(p_char));
// altitude
p_char1++;
          *p_char = 0;
strcpy(str_alt, (char *)(p_char1));
// UTC time
p_char++;
          *p_char1 = 0;
strcpy(str_time, (char *)(p_char));
// TTFF
p_char1++;
          *p_char = 0;
// num
p_char++;
          *p_char1 = 0;
// speed
p_char1++;
          *p_char = 0;
strcpy(str_speed, (char *)(p_char1));
return ret_val;
There is this part, as well.
// UTC time
p_char++;
          *p_char1 = 0;
I hope, I provided you enouhg information
PaulS
You mean that you don't know how to parse the time. You should start with printing the data as obtained from the GPS. Modify the library if needed.
If the date/time stamp in the GPS data looks like 20130617062400.345, then taking 4 characters for the year, 2 for the month, 2 for the day, 2 for the hour (GMT), 2 for the minute, and two for the second seems reasonable. The millisecond portion follows the decimal point, but may be more than you need.
Sembazuru
And, because this is a GPS generating the time, it would be UTC not your local time (unless you happen to be in GMT and either don't use summer time, or it is winter). Because timezones are defined politically, not necessarily geographically, it would take a huge database (probably larger than an UNO could hold) to be able to accurately figure out the timezone correction based on the Lat/Lon/date for every point on the Earth...
http://www.catb.org/jargon/html/I/I-didn-t-change-anything-.html
pierrot10
by the bay, what it's the limite of a buffer
coords[100]
I change it to 300 and nothing was working...
PaulS
The limit is when the heap and the stack overlap. Since both are dynamically modified at run time, there is no fixed limit.
I change it to 300
Why? The 90 characters you were storing fit in the 100 element array.
Tom Carpenter
But on top of those 90 characters are the extra 20 characters of text such as "&long=", so 100 characters is possibly not quite enough. Maybe 110 or so would be better.
~Tom~
PaulS
What is not clear is why the data needs to be copied from existing char arrays into one huge array. There are methods in the most output libraries to output data in smaller chunks. The system on the other end won't be able (generally) to tell the difference between 110 output statements and one output statement.
RudiAhlers
many thank
That is a readable format. Look again: 2013 (year) 06 (month) 09 (day) 06 (hour) 24 (minute) 00.097
