Topic: Transceiver nRF24L01+ Module with Chip Antenna (Read 1 time) previous topic - next topic
For my application, I plan on having two nRF24L01+ Modules communicating with each other. They will each be placed in plastic enclosures and need to communicate over no more than 3-4 meters with the potential for people to walk between the enclosures.
From any experience with the chip antenna module (https://www.sparkfun.com/products/691), does anybody know if these boards will be ok or will I need to look at using a different antenna arrangement from another board using the nRF24L01+.
I got about 10m range using these modules with chip antenna, I doubt many people
have gotten the 100m range they mention.
i hardly think that the test conditions were anything but favorable... that datum is one that isn't usually reported.. Your Milage may vary.
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
have you tried dropping data rate to 250kbps ?
i get about 15m through walls . which is pretty decent.
i haven't tried enclosing them as yet but i should imagine they would still work
Confirm your email address
Thank you for subscribing!
via Egeo 16
Torino, 10131
