Topic: Controlling 3 LEDs with one constant current circuit (Read 3195 times) previous topic - next topic
TanHadron
I have a red, a green, and a blue LED that I need to light up brightly.  Only one at a time, though.  My project is run from batteries, and I would like the brightness to not diminish as the batteries lose voltage.  I understand that is what a constant current circuit is for.
Can I just use one LM317 adjustable voltage regulator, or would I need 3, or is there an easier way?  Do people usually use ws2801 or something?
KirAsh4
If you choose to use a WS2801, read its datasheet as it explains how to create a constant current setup.
fungus
Yes.
(...and 10/10 for correct thinking - very rare around here!)
You can do it with 1 if you're only going to light up 1 LED at a time. Nothing will die if you turn all of them on but the brightness won't be what you want.
Easier then a LM317 + resistor? Probably not.
If I wanted to light up more than one I'd do it with one of these or (this - same thing). Yes, it's a VU meter but if you tie pin 7 to VCC you get five constant-current pins, no other components needed, and  they take up less space on a PCB than resistors/whatever. You can also connect pin 7 to an Arduino pin and PWM it or whatever. Worth buying a few dozen if you're going to play around with LEDs...
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
KirAsh4
That second URL takes you to eBay's categories page.  Perhaps you meant this page instead?
sonnyyu
#4
Jun 17, 2013, 07:18 pm Last Edit: Jun 17, 2013, 08:13 pm by sonnyyu Reason: 1
The battery powered LED has key issue is power efficiency, the higher efficiency  the longer battery last.  Your battery type (voltage, Ah) and LED w ( current, A) as well as dimmable will determine the LED drive IC.
TanHadron
Thanks for the responses, guys.  I also found an LED driver from Mouser that looks pretty easy.  I'm not sure it will work--all the sample schematics show multiple LEDs hooked up in series and I only have one at a time.  Especially the red one that runs at 2.0 volts.
I guess I'll buy a few and hook one up and see how it goes.
KirAsh4
Page 4 of the datasheet, under 'Single LED string':
Quote
The number of the LEDs can vary from one to an unlimited number. T
TanHadron
Very good.  I'm sure the thing has no idea how many LEDs I have hooked up in series.  The question is if it can handle voltages that low.
Figure one, the graph that shows current regulation vs anode-cathode voltage, probably tells the important number here.  If only I could blow up that graph and see where the 2.0 volt mark hits.  I'm not so sure it will be in the 20 mA area.  I think it will be OK with the green and blue LEDs at 3.2 volts, but the red one might be a little bit low.
Docedison
Red LED's typically require 20 mA @ 1.8 - 2V.. So 2V might be just right.
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
TanHadron
Well, the NSI45020AT1G doesn't work for what I need.  Neither does the LM317.
If I use 8 volts supply, it works great.  But if I only use 5 volts, my blue and green LEDs don't get full 20 mA.  If I use 3.7 volts, none of my LEDs gets the right current.  I need this to work down to at least 4.0 volts.  3.7 would be even better.
Bummer.
foxdown
right,our battery type (voltage, Ah) and LED w ( current, A) as well as dimmable will determine the LED drive IC.
fungus
Datasheet says it needs 1.8V overhead to work so a 3.6V LED needs a 5.6V power supply.
Same problem.
