Topic: Arduino Uno Record and Playback 433.92mhz signals via web interface (Read 4178 times) previous topic - next topic
kiwinol
Hi Everyone,
I would like to record and playback 433.92mhz signals using an arduino uno.  I have bought the following transmitter and reciever:
http://dx.com/p/diy-433mhz-wireless-receiving-module-for-arduino-green-149252
http://dx.com/p/433mhz-wireless-transmitter-module-superregeneration-for-arduino-green-149254
I also have a network shield for my arduino as firstly I was thinking of doing all the processing and storing/receiving information on the backend in my raspberry pi with somthing like a python script and an sqlite database.
Has anyone already seen anything similar done?
This is the closest I have been able to find as an example:
http://blog.rogiervandenberg.nl/2013/03/control-lights-with-arduino-remotely.html
Any input or ideas would be welcome.  I am still waiting for my Arduino to arrive.
llukkari
#1
Jun 17, 2013, 02:59 pm Last Edit: Jun 17, 2013, 03:01 pm by llukkari Reason: 1
I did something similar:
https://github.com/lasselukkari/Arduino-RC-Timer-Switch
It's just a POC and I'm not planning to develop it any further.
kiwinol
Thanks llukkari  :)
That looks very interesting.  I will check it out and give you an update once my gear arrives and I get a chance to try it!
gardner
You might find the capabilities of the receiver you mentioned to be limited.  I gave up on the very cheap ones and wound up with these receivers:
http://www.robotshop.com/content/PDF/receiver-specifications-rxa30-434-2-5n.pdf
I found that dissecting the signals from random transmitters was possible, but a bit challenging.  Here's my writeup from the project I did:
http://1474orchard.ca/projects/?x=entry:entry130102-153246
There are other similar writeups for other weather stations and similar wireless doodads that I found when I was working on mine.  The biggest challenge I found was correctly reverse engineering the checksums.  In my case I could read and validate the interesting information without needing the checksum.  I think if you were recording and playing back, you could just play back the checksum without knowing how it's computed.
kiwinol
Hi gardner,
Sorry I took so long to reply. I am still waiting for my components :)  Thanks for your input too I will let you know how I get on!
joanba
I've did a similar project, recording analog sensor data for watering my garden. Just take a look at http://maslestorres.cat
But I'm process of updating the datalogger part with v2.0:
v1.0 - arduino UNO + XBee shield, tied via USB/serial to a computer with sqlite and a Objective-C development to save data in a Mac mini.
v2.0 - arduino Mega + XBee shield with RTC and SD + Display. Autonomous unit but when connected to the Mac mini saves data to sqlite. Objective-C code handling serial data replaced by a phyton script which is by far simple and powerful.
v3.0 - I'm just thinking about it... Raspberry PI with sqlite, but how to get XBee data ? Arduino Yún ?
