Topic: seconds timekeeping (Read 1 time) previous topic - next topic
gardner
I sometimes wish there was seconds timekeeping in the Arduino core.  For a recent project, I implemented seconds timekeeping in wiring.c as follows.
See http://forum.arduino.cc/index.php?topic=172419.0 for some libraries to use this.
I reviewed a couple of "userland" tools for timekeeping based on millis(), but the code complexity is high and the overhead of constantly reading millis() and correlating to a userland seconds timekeeping is pretty high.  I want something where the normal timer interrupt does the work.  My solution adds a dozen instructions to the timer0 overflow and 6 bytes of static variables.
Code: [Select]
volatile unsigned long timer0_sec = 0;
static unsigned int timer0_sec_fract = 0;
#if defined(__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
ISR(TIM0_OVF_vect)
#else
ISR(TIMER0_OVF_vect)
#endif
// copy these to local variables so they can be stored in registers
// (volatile variables must be read from memory on every access)
unsigned long m;
unsigned int f = timer0_fract;
m = MILLIS_INC;
f += FRACT_INC;
if (f >= FRACT_MAX) {
f -= FRACT_MAX;
m += 1;
timer0_fract = (unsigned char) f;
timer0_millis += m;
timer0_overflow_count++;
/* Also keep track of seconds
f = timer0_sec_fract + m;
if (f >= 1000) {
            timer0_sec += 1;
    f -= 1000;
timer0_sec_fract = f;
void time_set(unsigned long t)
   uint8_t oldSREG = SREG;
   cli();
   timer0_sec = t;
   SREG = oldSREG;
unsigned long time_sec()
   unsigned long m;
   // disable interrupts or we might get an
   // inconsistent value (e.g. in the middle of a write)
   cli();
   m = timer0_sec;
   SREG = oldSREG;
   return m;
johnwasser
How is that different from:
Code: [Select]
static unsigned long timerStart = 0;
// Set the current time in seconds
   timerStart = millis() - (t*1000UL);
// Return the current time in seconds
   return (millis() - timerStart) / 1000UL;
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
gardner
It does not wrap after a few days like millis() does.
johnwasser
The millis() timer wraps after about 47 days.  The version I wrote should work properly across the wrap so unless you are measuring a single interval greater than 46 days it shouldn't be a problem.
gardner
I do not see that.  millis() is unable to tell the difference between now and 49 days 17 hours ago, or  49 days 17 hours from now.  A simple unchanging offset doesn't fix that.  To use millis() as the base timer for a longer term clock you have to guaranty that you sample millis() often enough (at least every two dozen days) to spot when it rolls over, and adjust the offset.  There are several implementations of that around, but they are more complex than what I wanted.
Quote
That is the requirement.
CrossRoads
So you are not going to look at the time for 49 days at a time?
What a patient program.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
