Topic: led lamp + arduino (Read 3235 times) previous topic - next topic
antoniore
Hi guys I'm new in the forum my name is antonio. I would ask if I can adapt a circuit diagram of a lamp 90 LEDs in series, on a controller arduino ... What should I change? by attaching the link of the related wiring diagram.
Thanks again but I am novice.
http://www.wutel.net/ecoledlamp006/
8) 8)
antoniore
http://www.wutel.net/ecoledlamp006/file_ecoledlamp006/fotoschema%20per%20lampada%2090%20led%20a%20220V.jpg
fungus
What do you want to do with them? Why do you need an Arduino?
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
antoniore
Meanwhile, thanks for taking my call ... I would like to connect the whole ceiling led to arduino to control the switching on and off of the LEDs, (all the LEDs are connected in series), also put a temperature sensor, which at the moment here in the room temperature will be> 35 degrees, the fans will turn on them also 220 volts. I hope I was clear. thanks if you know me lend a hand, at least in drafting the project and its components.
fungus
Look for "solid state relay". This allows you to switch any 220V AC device on/off using an Arduino.
antoniore
thanks for the tip on the rss, but how do I mount? the sensor should be between 220 volts and the controller arduino? and then on the breadboard I mount the resistors and LEDs?
fungus
If you don't understand the electronics then better buy a kit: eg. https://www.sparkfun.com/products/10684
You can't mount 220V AC devices on a breadboard, the board will burn.
antoniore
Hello to all I would like to build a LED lamp with arduino to illuminate a room, you should build the lamp at 220 volts or 5 volts with the usual arduino?
(I'm electrician so I know the risks of the 220 ??volt)
I'm hoping for some help from those who know more than me in the "arduino"
antoniore
okkkkk I had already seen and considered the 'purchase a kit ... then connect the load to 220 volts and 5 volts output ctrl gnd for arduino right?
sorry but I am at the beginning and I'm trying to learn everything well;) :)
fungus
#9
Jun 18, 2013, 10:10 pm Last Edit: Jun 18, 2013, 10:13 pm by fungus Reason: 1
Yes. The Arduino connects to the bit that says "DC" on it.
If you don't understand transistors and resistors then a kit is much easier. You can also get multi-channel relays, look for "Arduino SSR" on eBay.
fungus
Please don't create multiple threads for the same question.
antoniore
this .:??http://www.ebay.com/itm/5V-1-Channel-Relay-Module-Shield-for-Arduino-ARM-PIC-AVR-DSP-SRD-05VDC-SL-C/370834105074?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D16098%26meid%3D8472365501734379536%26pid%3D100005%26prg%3D7683%26rk%3D2%26sd%3D250997117496%26
can show me please a rtc too? i have to put it to control led's turn on and turn off
thank you very much  :smiley-roll-blue:
antoniore
this is my project  :smiley-roll-blue: :smiley-roll-blue:
nickgammon
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
antoniore
Threads merged.
- Moderator
i'm sorry ...
