Topic: ARDUINO and SIM 900 / GPS S1315RL (Read 12384 times) previous topic - next topic
mkbutan
Jun 18, 2013, 04:16 pm Last Edit: Jun 18, 2013, 08:00 pm by mkbutan Reason: 1
Hi
I have added the GSM Library but still it gives Errors
Code
Code: [Select]
[I]#include <GSM.h>
#include <GSM3CircularBuffer.h>
#include <GSM3MobileAccessProvider.h>
#include <GSM3MobileCellManagement.h>
#include <GSM3MobileClientProvider.h>
#include <GSM3MobileClientService.h>
#include <GSM3MobileDataNetworkProvider.h>
#include <GSM3MobileMockupProvider.h>
#include <GSM3MobileNetworkProvider.h>
#include <GSM3MobileNetworkRegistry.h>
#include <GSM3MobileServerProvider.h>
#include <GSM3MobileServerService.h>
#include <GSM3MobileSMSProvider.h>
#include <GSM3MobileVoiceProvider.h>
#include <GSM3ShieldV1.h>
#include <GSM3ShieldV1AccessProvider.h>
#include <GSM3ShieldV1BandManagement.h>
#include <GSM3ShieldV1BaseProvider.h>
#include <GSM3ShieldV1CellManagement.h>
#include <GSM3ShieldV1ClientProvider.h>
#include <GSM3ShieldV1DataNetworkProvider.h>
#include <GSM3ShieldV1DirectModemProvider.h>
#include <GSM3ShieldV1ModemCore.h>
#include <GSM3ShieldV1ModemVerification.h>
#include <GSM3ShieldV1MultiClientProvider.h>
#include <GSM3ShieldV1MultiServerProvider.h>
#include <GSM3ShieldV1PinManagement.h>
#include <GSM3ShieldV1ScanNetworks.h>
#include <GSM3ShieldV1ServerProvider.h>
#include <GSM3ShieldV1SMSProvider.h>
#include <GSM3ShieldV1VoiceProvider.h>
#include <GSM3SMSService.h>
#include <GSM3SoftSerial.h>
#include <GSM3VoiceCallService.h>[/I]
[COLOR="#FF0000"][B]#include "SIM900.h"[/B][/COLOR]
#include <SoftwareSerial.h>
[B][COLOR="#FF0000"]#include "sms.h"[/COLOR][/B]
[COLOR="#FF0000"][B]SMSGSM sms;[/B][/COLOR]
  Serial.println("GSM Testing to send SMS");
  if (gsm.begin(2400)){
    Serial.println("\nstatus=READY");
    started=true;
  else Serial.println("\nstatus=IDLE");
  if(started){
    if (sms.SendSMS("+919987687631", "Arduino SMS"))
    // number to which you want to send the sms and the sms text//
    Serial.println("\nSMS sent OK");
ERROR
Quote
sketch_jun18e.ino:36:20: error: SIM900.h: No such file or directory
sketch_jun18e.ino:40:17: error: sms.h: No such file or directory
sketch_jun18e:42: error: 'SMSGSM' does not name a type
sketch_jun18e.ino: In function 'void setup()':
sketch_jun18e:48: error: 'gsm' was not declared in this scope
sketch_jun18e:50: error: 'started' was not declared in this scope
sketch_jun18e:54: error: 'started' was not declared in this scope
sketch_jun18e:55: error: 'sms' was not declared in this scope
I am using ARDUINO 328 and its IDE is 1.0.5
Please help me to rectify these errors
also how and from where to Download SIM900.h & SMS..h File or Directory
Thanks in advance
"THE LIFE IS VERY SMALL TO LEARN ELECTRONICS"
                           ??????°?i??
                           AND
                           yes
                           PROGRAMMING
jatan
i am also using the same gsm module and i am unable to send message
karthikreddy
please check your GSM modem initially without using any library use Serial to do so like sending AT   ATD n more AT commands fine?
arungsystems
#3
Sep 05, 2013, 12:45 am Last Edit: Sep 05, 2013, 01:00 am by Arun G Reason: 1
If u include all GSM Library it will gives Errors only..
you have to include the proper libraries. I am using SIM900A GSM module. Code to send message to a particular number follows
Code: [Select]
#include "SIM900.h"
#include <LiquidCrystal.h>
#include "sms.h"
SMSGSM sms;
LiquidCrystal lcd(12, 11, 10, 9, 8, 7);
int started;
 Serial.println(" Motor control");
 lcd.begin(16, 2);
 lcd.setCursor(1, 0);
 lcd.print("Arduino Uno");
 lcd.setCursor(1, 1);
 lcd.print("Motor control");
   Serial.println("\n READY");
   lcd.clear();
   lcd.print("READY");
   started= 1 ;
   Serial.println("\n IDLE");
   lcd.clear();
   lcd.print("IDLE");
 if(started == 1){
   if (sms.SendSMS("+91 XXXXXXXXXX", "SMS sent by Arduino")) // number to which you want to send the sms and the sms text//
   Serial.println("\n Message sent");
   lcd.print("Message sent");
click this link http://www.gsmlib.org/
download the latest file, include the library in your ide(Import library option)...
connections:
         GSM rx - DIGITAL 3pin,
         GSM tx - DIGITAL 2pin,
         make sure that u have common GND.
