Topic: 74HC595 - led won't light up (Read 923 times) previous topic - next topic
traffiq
i played around with the 74HC595 today and followed the playground tutorial regarding this piece of hardware.
The problem is that non of my leds are willing wo light up. I tripple checked the wireup and im sure this is not the problem.
I can measure voltage on the output pins of the 74HC595. Here is a foto of the setup:
After hours of searching i loaded up the blink sketch ( pin13 high/low ) and wired up an led with a 220ohm resistor to it.
The funny thing now is that even that LED is not willing to light up. I check that the anode is in the right direction.
So i tried something even more basic:
I wired the resistor and the led to the 5V output of the arduino and wired the cathode to a ground pin.
Nothing happend :( Could it be that i somehow fried my arduino ?
What should be my next steps ?
Thank you :)
traffiq
So after playing around i finally got a single led to blink :)
The thing to remember was that a row on a breadboard is connected. So when i inserted a LED with anode + cathode into the same row i basicly shortcuted the way fpr the current - avoiding my led :/
Sorry, im dumb :)
*close please
LarryD
Quote
im dumb
This serves no useful purpose.
You learn from your mistakes, like all of us.
You won't make the same mistake, until you get older ;)
No technical PMs.
The last thing you did is where you should start looking.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
