Topic: need help to write a code please (Read 2930 times) previous topic - next topic
dany151
Jun 19, 2013, 04:38 pm Last Edit: Jun 19, 2013, 04:40 pm by dany151 Reason: 1
Kindly, i want to write a code for read  analog signal 10 times and put these reading in a matrix as
for (int i=0;i<10;i++) {
   a[i]=readRead(A0);
then i compare the elements of matrix if they belong to another matrix contain 50 elements as
int b[50] = { 512,519,520,600,...........................,400};
i do not want to make a loop to compare 50 times cause it will take a long time...i want a code to check with minimum time
AWOL
Tell us what you want to do, not how you think you should do it.
KeithRB
Sorry, but brute force is sometimes the only way to go.
However, I think you are going to have problems with this just because of the noise inherent in reading the analog input, I don't think a check for exact equality will work very well.
Are you trying to match a pattern, or single values?
A binary search will cut the time a lot, as well as hashing.
dany151
i have 4 analog signal patterns i want to check if the reads belongs to which  pattern...so that i will make a database for each pattern then check if the new signal belong to the pattern with acceptable error rate
dany151
good point
it must have some error rate
KeithRB
Use a hash or binary search to see if the first element is in the pattern array. Then check each one in turn, as soon as it fails to find a match quit the search.
Remember, the arduino does not have much memory for a "database".
dany151
good idea
i will take it in my account..thank you
-----------------------but i want to check all the readings at the same time please help
Arrch
Define "same time".
To the Arduino?
To the human eye?
To a Physicist?
dany151
Define "same time".
To the Arduino?
To the human eye?
To a Physicist?
AWOL
Is there something wrong with your question-mark key?
Arrch
Define "same time".
To the Arduino?
To the human eye?
To a Physicist?
"same time" is subjective. It sounds like you want to do this process with respect to the Arduino. Unfortunately, the Arduino doesn't have a "compare array of values to withing a specific threshold" instruction.
Sembazuru
Define "same time".
To the Arduino?
To the human eye?
To a Physicist?
Time scales are relative...
To the Arduino, the "same time" is on the order of microseconds.
To the human eye, the "same time" is on the order of 100's of milliseconds.
To a Physicists I work with, the "same time" is on the order of picoseconds (or smaller).
To a Geologist, the "same time" is on the order of hundreds of years (or larger)...
http://www.catb.org/jargon/html/I/I-didn-t-change-anything-.html
dany151
i think it need a statistical operation to do like  this things
for me i process human eye signal with arduino...
Arrch
Like what things? Can you try that sentence again?
dany151
like find the Mean absolute error or Mean squared  error
