Topic: [no need to read]Problems with servo's and hardware Serial (Read 906 times) previous topic - next topic
Filip_J
Jun 19, 2013, 06:49 pm Last Edit: Jun 20, 2013, 03:43 am by Filip_J Reason: 1
Hi All
i'm quite new to this forum, so i hope this is the proper place to put this up:)
as the title suggests: I'm having problems with my serial connection when i include the servo library.
I'm currently working on a C# library for communicating with the Arduino ( also made a library for arduino). just a simple protocol for data transfer between them.
so here' s the deal: i've set it up  so that i have packet that looks like this
"ID" 1 byte -> for deciding what kind of packet i'm recieving/sending;
"Package Size" 1 byte -> for determing when i have received the entire package
"payload"
its working like a charm until i include the servo library.
the arduino sends my package like this (O represents an OK byte while X represents a random zero)
OXOXOXOXOXOX for a 6 byte package.
while the incoming bytes are just fine.
any help will be appreciated
Erdin
We have to know more.
Which Arduino board are you using ?
Do you connect a servo motor to the board ? how ?
Could you upload you sketch between code tags ? (use the '#'-button above the text input field).
Does your library/sketch declare an array of hundreds of bytes ?
Does your library/sketch use a hardware timer ?
zoomkat
Servo test code that uses the hardware serial port.
Code: [Select]
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7, 500, 2500);  //the pin for the servo control, and range if desired
  Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    int n = readString.toInt();  //convert readString into a number
    // auto select appropriate value, copied from someone elses code.
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
    readString=""; //empty for next input
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Filip_J
Hi again thanks for the response seems i was just being silly and somehow had a line in my c# code like this
                    int size = Port.BytesToRead;
                    while (size> 0)
it shoulhave been an if statement this way i would randomly read things normaly ( if 1 byte was recieved ) or very weirdly (if more bytes were recieved)
sorry again guys
