Topic: TLC5940mux.h with 74hc595 Mega2560, raw 3 and raw 7 issue.. (Read 565 times) previous topic - next topic
prasadrathnayake
Jun 20, 2013, 05:15 am Last Edit: Jun 20, 2013, 07:02 pm by rat47 Reason: 1
I'm plan to drive 5x8 rgb led matrix with Mega 2560. Almost there with TLC5940Mux.h, but raw 3 and raw 7 is not functioning... Other all raws are fine and act as expected...
Please help if anyone can ...
Code: [Select]
#include "Tlc5940Mux.h"
#define  NUM_TLCS  1
#define  NUM_ROWS  8
// SHIFT_DATA_PIN (PC0 is analog 0) = '595 SER pin (Pin 14)
#define SHIFT_DATA_PORT PORTC
#define SHIFT_DATA_PIN  PC0
#define SHIFT_DATA_DDR  DDRC
// SHIFT_CLK_PIN (PC1 is analog 1) = '595 SRCLK (Pin 11)
#define SHIFT_CLK_PORT  PORTC
#define SHIFT_CLK_PIN   PC1
#define SHIFT_CLK_DDR   DDRC
// '595 RCLK is hooked to tlc XLAT pin (Arduino digital Pin 9, 74HC595 Pin 12)
volatile uint8_t isShifting;
uint8_t shiftRow;
static inline void shift8_595_row(uint8_t row)
  // the output of the '595 for the selected row should be high, all others
  // low
  uint16_t output = (1 << row);
  uint16_t nbit = 1 << (NUM_ROWS - 1); //0x80;
  for (; nbit; nbit >>= 1) {
    if (nbit & output) {
      SHIFT_DATA_PORT |= _BV(SHIFT_DATA_PIN);
    else {
      SHIFT_DATA_PORT &= ~_BV(SHIFT_DATA_PIN);
    // pulse the '595 sclk
    SHIFT_CLK_PORT |= _BV(SHIFT_CLK_PIN);
    SHIFT_CLK_PORT &= ~_BV(SHIFT_CLK_PIN);
ISR(TIMER1_OVF_vect)
  if (!isShifting) {
    disable_XLAT_pulses();
    isShifting = 1;
    sei();
    TlcMux_shiftRow(shiftRow);
    shift8_595_row(shiftRow);
    PORTC = shiftRow++;
    if (shiftRow == NUM_ROWS) {
      shiftRow = 0;
    enable_XLAT_pulses();
    isShifting = 0;
void test()
for(int x=0; x<8; x++){
  TlcMux_clear();
  TlcMux_set(x, 0, 4095);
  delay(100);
  TlcMux_clear();
  TlcMux_set(x, 1, 4095);
  delay(100);
  TlcMux_clear();
  TlcMux_set(x, 2, 4095);
  delay(100);
  SHIFT_DATA_DDR |= _BV(SHIFT_DATA_PIN);
  SHIFT_CLK_DDR  |= _BV(SHIFT_CLK_PIN);
  DDRC |= _BV(PC0) | _BV(PC1) | _BV(PC2);
  TlcMux_init();
uint8_t color;
delay(1);
  for (uint8_t col = 0; col < 11; col++) {
    for (uint8_t row = 0; row < NUM_ROWS; row++) {
      TlcMux_set(row, col + color * 16, 4095);
    color++;
    if (color == 3) {
      color = 0;
  test();
