Topic: Windows 7 pro 64bit driver for DUE ??? (Read 1 time) previous topic - next topic
kapelan
Hi I'm trying to install DUE from this guide:
http://arduino.cc/en/Guide/ArduinoDue
after this step:
"Navigate to the folder with the Arduino IDE you downloaded and unzipped earlier. Locate and select the "Drivers" folder in the main Arduino folder (not the "FTDI USB Drivers" sub-directory). Press "OK" and "Next" to proceed. "
Windows just saying the best driver already installed and does not give any other option.
Anybody know how to install the driver?
exedor
where is the device showing up in the device tree?  You can delete it, then rescan for devices, right click it, click update driver software and then make sure you don't choose have windows search for a driver and instead browse.  Point at the drivers subdirectory and uncheck the "search all sub-directories" option.  It still shows up as a COM port under the serial devices tree. I've also found the IDE to be a little flaky at finding it.  You also need to make sure you have the right board selected before you go looking for the com port in the IDE menu.
kapelan
this pictures are the same on AMD and Intel
Louis Davis
What is the Hardware ID for the Unknown Device in device manager?
Go to Device Manager
Right Click Unknown Device in Device Manager
Select Properties
Select Details tab
Change Property to Hardware Ids
What is displayed under Value?
kapelan
Louis Davis
The system is having a problem reading the USB descriptors from the DUE.
Some things to check:
Try a different USB cable.
Does your system have USB 3.0 ports? If so, try a USB 2.0 port.
Does is make a difference if you use the programming USB port vs. native USB port on the DUE?
kapelan
Thank you,
different USB cable fixed the problem.
Looks like reliability of wires worse then quality of device :(
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
