Topic: dimming and running LEDs (Read 3430 times) previous topic - next topic
Peter_Lam
Hi all,
I am still new to Arduino, I have a project to do.
I wanted to run LEDs in a running pattern, once I pressed and hold down the buttons, the LEDs keep running.
At the same time I have a 4-position rotary switch to select the brightness of LEDs
Here is the code
Code: [Select]
byte button = 7;
//byte led = 9;
byte led[4] = {2,3,4,5}; // 4 leds.
byte rSwitch[4] = {8,9,10,11}; // 4-position rotary switch
byte brightness;
pinMode(button, INPUT);
for(int i = 0; i<4; i++)
pinMode(led[i], OUTPUT);
digitalWrite(led[i], LOW);
for(int a = 0; a<4; a++)
pinMode(rSwitch[a], INPUT);
if(digitalRead(button) == HIGH) {// if button is pressed
  if(digitalRead(rSwitch[1]) == HIGH {  //select 1st brightness
    brightness = 10; // set brightness
    blink_led_task();
  } // blink button
  if(digitalRead(rSwitch[2]) == HIGH {  //select 2nd brightness
    brightness = 50; // set brightness
    blink_led_task(); // blink button
  if(digitalRead(rSwitch[3]) == HIGH {  //select 3rd brightness
    brightness = 100; // set brightness
  if(digitalRead(rSwitch[4]) == HIGH {  //select 2nd brightness
    brightness = 200; // set brightness
digitalWrite(led[i], LOW); // turn off all led.
unsigned long blink_led_time;
void blink_led_task()
if(millis() - blink_led_time > 500) // 200 ms.
blink_led_time = millis();
return;
static byte number = 0;
digitalWrite(led[i], LOW); // turn off all leds first.
analogWrite(led[number], brightness);
number++;
if(number == 4)
number = 0; // reset back to zero.
// digitalWrite(led, digitalRead(led) ^ 1); // toggle led.
It does not compile, says there is something wrong about the bracket.
I did check but I can't see the problem.
Can anyone give me some hints or suggestion ?
Cheers
larryd
#1
Jun 20, 2013, 06:42 am Last Edit: Jun 20, 2013, 06:57 am by LarryD Reason: 1
Quote
Hints:
Look carefully at setup() for the missing brace
if(digitalRead(rSwitch[1]) == HIGH     <<<<<<  is this ok?  Maybe there is more
digitalWrite(led[ i ], LOW); // turn off all leds first.<<<<< Do you need to
analogWrite(led[number], brightness);            <<<<<  do something here?
number++;
In order to make your code more readable, always go to tools/Auto Format  in order to make your code more readable
Edit:
Also, you may find it beneficial to line up your braces
  if(digitalRead(rSwitch[1]) == HIGH {  <<<<move to the next line
 // Line the braces up
      blink_led_task();
 } // blink button
No technical PMs.
The last thing you did is where you should start looking.
Peter_Lam
#2
Jun 20, 2013, 09:15 am Last Edit: Jun 20, 2013, 10:47 am by Peter_Lam Reason: 1
Thanks for your reminding about the Tools > Auto Edit
I reviewed my code again and found out what brackets are missing.
Code: [Select]
byte button = 7;
byte led[4] =
byte rSwitch[4] =
unsigned long int brightness;
  if(digitalRead(button) == HIGH) // if button is pressed
    if(digitalRead(rSwitch[1]) == HIGH)  //select 1st brightness
      blink_led_task(); // blink LED function
    else if(digitalRead(rSwitch[2]) == HIGH)  //select 2nd brightness
    else if(digitalRead(rSwitch[3]) == HIGH)  //select 3rd brightness
    else if (digitalRead(rSwitch[4]) == HIGH) //select 2nd brightness
  if(millis() - blink_led_time > 500) // 500 ms.
    return;
  number++;
  if(number == 4)
it compiles.
I uploaded it to my Mega 2560 to see it works as expected. Unfortunately not.
Quote
Hints:
number++;
Edit:
      blink_led_task();
 } // blink button
I turn the LEDs off just want to make sure they would not be turned on before the sequence starts. I know it may be not necessary in this case.
Originally, I developed a code which only contains the ON button and LEDs, no brightness/dimming control.
That worked fine. But it goes wrong after I added the rotary switch for dimming.
larryd
#3
Jun 20, 2013, 07:40 pm Last Edit: Jun 20, 2013, 07:44 pm by LarryD Reason: 1
Can you confirm ALL switches have pull resistors (you could use internal ones) and when they close they go to 0 volts (GND)?
Arrays start at 0
http://www.thebox.myzen.co.uk/Tutorial/Arrays.html
if(digitalRead(rSwitch[0]) == HIGH {  //select 1st brightness
FYI: some sketch applications have to have switches de-bounced.
No technical PMs.
CrossRoads
Change this to
pinMode(rSwitch[a], INPUT_PULLUP); // enable internal pullups
and then read if they got pulled Low & act on that:
if(digitalRead(rSwitch[0]) == LOW) {
CrossRoads
Or be clever about the rotary switch:
Code: [Select]
rSwitch = PINB & B00001111;  // read PortB, mask off the upper 4 bits
switch(rSwitch){  // faster than a bunch of if statements
case 0x01:
case 0x02:
case 0x04:
case 0x08:
// no valid cases selected
PORTB = PORTB & B11110000; // clear lower 4 bits, leave upper bits as they were
} // end switch:case
larryd
Quote
PINB
Did not know about Port Manipulation, thank you very much, just goes to show you that you might learn something by reading a Post!
No technical PMs.
CrossRoads
You might indeed 8)
I still use pinMode to set the pins as INPUT & OUTPUT in setup, makes it easier for me to keep track of.
Peter_Lam
Change this to
I dun understand this , does the INPUT_PULLUP make a difference ?
If I change the rSwitch into pullup, do I have to change the ON/OFF button as well ??
Peter_Lam
Arrays start at 0
I think I do not have anything to do with pull up resistor in this project. (I think)
I connect the ON/FF button following this basic method:
http://arduino.cc/en/tutorial/button
The 4 pins of rotary switch is also connected like that.
It does work without the rotary switch.
Peter_Lam
This is my old code:
Code: [Select]
byte button = 8;
byte led[4] = {
    return;
  digitalWrite(led[number], HIGH);
  number++;
  if(number == 4)
It works fine.
CrossRoads
You said the dimming didn't work with the rotary switch, I was offering suggestions to fix that.
The PULLUP makes sure the pins do not float. They are either HIGH from the pullup, or LOW when connected to Gnd with your switches. Wire your switch so that it connects the selected pin to Gnd. I imagine you have it connected to +5 right now?
Peter_Lam
yes, both ON/OFF button and rotary switch connected to the 5V pin of mega 2560.
5V ------ Button  ------ [resistor] ----- GND
                         Input Pin
This is how I connect them.
CrossRoads
Lose the resistor, put the button where the resistor was, no external connection to 5V. Only the  internal pullup resistor.
Change the software logic to look for a Low when the button is pressed.
if (digitalRead (inputPin) == LOW){
//then button was pressed, so do something
else {
// button was not pressed,  do something else, or not
Peter_Lam
else {
Just changed the wiring and the code as you suggested.
Here is the code
Code: [Select]
byte button = 7;
byte led[4] =
byte rSwitch[4] =
  pinMode(button, INPUT_PULLUP);
  if(digitalRead(button) == LOW) // if button is pressed
    if(digitalRead(rSwitch[0]) == LOW)  //select 1st brightness
    else if(digitalRead(rSwitch[1]) == LOW)  //select 2nd brightness
      brightness = 60; // set brightness
    else if(digitalRead(rSwitch[2]) == LOW)  //select 3rd brightness
      brightness = 120; // set brightness
    else if (digitalRead(rSwitch[3]) == LOW) //select 2nd brightness
    return;
  number++;
  if(number == 4)
It works now, thank you so much for your advise.
I tried to use the switch case as you mentioned previously, it doesn't compile.
