Topic: Slotted, non-blocking delays against millis() (Read 6805 times) previous topic - next topic
funlw65
Hi, i will try to make a "short" introduction first and I will try to explain what is all about (my native language is Romanian).
My journey in the microcontroller world started with PICAXE08M microcontroller, thanks to an australian friend and, obviously, I migrated later to true Microchip microcontrollers, where I learned to program them using the JAL language. We have there, inside jallib library collection, a library named timer0_isr_interval where you can define your own non-blocking delays.
Some how, is working like millis() function but in a different way. First, you must set the size of an array corresponding to the number of total non-blocking delays you need in your application. Then, in every cell of that array, you put a number representing the required delay in milliseconds. An interrupt will trigger at every millisecond and instead of a variable increment as in millis, it will decrement the values of every cell until those will equal zero. Periodically, in your program, you will check if your delay has become zero and that means that that delay has just expired and you do the task assigned to that delay. Then, you set the delay again at the initial value.
It is useful in simulating multitasking.
After a while, I decided that is the time to see what are those AVRs, what are they doing, and if their parents knows that! Obviously, as a good PIC programmer, I bricked my first ATmega32 and returned for awhile back to PICs. But I don't like to lose battles so I tried again with an ATmega644P (util I will make an AVR Doctor, my ATmega32 remains bricked). This time I was careful and I succeeded in transforming it into a Sanguino microcontroller. I started exploring Wiring language and I can recognize the educational value and the project completion speed it offers. But i don't like how it waste the microcontroller resources. Because of this, I moved to avr-gcc toolchain and a big help was the project of Mike, libarduino, hosted on googlecode.com.
I don't know yet too much about the interrupts and timers of AVRs but I succeeded in porting the slotted, non-blocking delays from JAL to avr-gcc looking at the millis() example. I decided to compare them and for that I took a project theme where you must simultaneously blink 3 LEDs at different speeds: 250, 500 and 750 milliseconds. So here are the two avr-gcc C examples:
Using millis():
Code: [Select]
#ifndef F_CPU
#define F_CPU 16000000U // required by Atmel Studio 6
#endif
#include <avr/io.h>
#include <avr/interrupt.h>
//#include <util/delay.h>
#define sbi(PORT, BIT) (_SFR_BYTE(PORT) |= _BV(BIT)) // set bit
#define tbi(PORT, BIT) (_SFR_BYTE(PORT) ^= _BV(BIT)) // toggle bit
#define FALSE 0
#define TRUE  1
#define clockCyclesPerMicrosecond() ( F_CPU / 1000000L )
#define clockCyclesToMicroseconds(a) ( (a) / clockCyclesPerMicrosecond() )
#define microsecondsToClockCycles(a) ( (a) * clockCyclesPerMicrosecond() )
// the prescaler is set so that timer0 ticks every 64 clock cycles, and the
// the overflow handler is called every 256 ticks.
#define MICROSECONDS_PER_TIMER0_OVERFLOW (clockCyclesToMicroseconds(64 * 256))
// the whole number of milliseconds per timer0 overflow
#define MILLIS_INC (MICROSECONDS_PER_TIMER0_OVERFLOW / 1000)
// the fractional number of milliseconds per timer0 overflow. we shift right
// by three to fit these numbers into a byte. (for the clock speeds we care
// about - 8 and 16 MHz - this doesn't lose precision.)
#define FRACT_INC ((MICROSECONDS_PER_TIMER0_OVERFLOW % 1000) >> 3)
#define FRACT_MAX (1000 >> 3)
volatile uint32_t timer0_overflow_count = 0;
volatile uint32_t timer0_millis = 0;
static uint8_t timer0_fract = 0;
//#if defined(__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
//ISR(TIM0_OVF_vect)
//#else
ISR(TIMER0_OVF_vect)
//#endif
// copy these to local variables so they can be stored in registers
// (volatile variables must be read from memory on every access)
uint32_t m = timer0_millis;
uint8_t f = timer0_fract;
m += MILLIS_INC;
f += FRACT_INC;
if (f >= FRACT_MAX) {
f -= FRACT_MAX;
m += 1;
timer0_fract = f;
timer0_millis = m;
timer0_overflow_count++;
void millis_init(void) {
#if defined(TCCR0A) && defined(WGM01)
sbi(TCCR0A, WGM01);
sbi(TCCR0A, WGM00);
#endif
// set timer 0 prescale factor to 64
#if defined(__AVR_ATmega128__)
// CPU specific: different values for the ATmega128
sbi(TCCR0, CS02);
#elif defined(TCCR0) && defined(CS01) && defined(CS00)
// this combination is for the standard atmega8
sbi(TCCR0, CS01);
sbi(TCCR0, CS00);
#elif defined(TCCR0B) && defined(CS01) && defined(CS00)
// this combination is for the standard 168/328/1280/2560
sbi(TCCR0B, CS01);
sbi(TCCR0B, CS00);
#elif defined(TCCR0A) && defined(CS01) && defined(CS00)
// this combination is for the __AVR_ATmega645__ series
sbi(TCCR0A, CS01);
sbi(TCCR0A, CS00);
#else
#error Timer 0 prescale factor 64 not set correctly
#endif
// enable timer 0 overflow interrupt
#if defined(TIMSK) && defined(TOIE0)
sbi(TIMSK, TOIE0);
#elif defined(TIMSK0) && defined(TOIE0)
sbi(TIMSK0, TOIE0);
#else
#error Timer 0 overflow interrupt not set correctly
#endif
uint32_t millis()
uint32_t m;
uint8_t oldSREG = SREG;
// disable interrupts while we read timer0_millis or we might get an
// inconsistent value (e.g. in the middle of a write to timer0_millis)
cli();
m = timer0_millis;
SREG = oldSREG;
return m;
uint32_t currentMillis, pLED1Millis = 0, pLED2Millis = 0, pLED3Millis = 0;
void main(void) __attribute__((noreturn));
void main(void) {
sbi(DDRD, 5);
sbi(DDRC, 6);
sbi(DDRC, 7);
millis_init();
sei();
while (1) {
currentMillis = millis();
if (currentMillis - pLED1Millis > 250) {
pLED1Millis = currentMillis;
tbi(PORTD, 5);
if (currentMillis - pLED2Millis > 500) {
pLED2Millis = currentMillis;
tbi(PORTC, 6);
if (currentMillis - pLED3Millis > 750) {
pLED3Millis = currentMillis;
tbi(PORTC, 7);
funlw65
#1
Jun 21, 2013, 03:56 am Last Edit: Jun 21, 2013, 03:25 pm by funlw65 Reason: 1
Using slotted, non-blocking delays:
Code: [Select]
#ifndef F_CPU
#endif
#include <avr/io.h>
#define FALSE 0
#define TRUE  1
#define DELAY_SLOTS  3 // the number of non-blocking delays we need
int16_t isr_countdowns[DELAY_SLOTS]; // the array where the "delays" are stored
//#define MILLIS_INC (MICROSECONDS_PER_TIMER0_OVERFLOW / 1000)
//volatile uint32_t timer0_millis = 0;
ISR(TIM0_OVF_vect)
#else
#endif
//uint32_t m = timer0_millis;
uint8_t f = timer0_fract, i, j;
i = 1;
//m += MILLIS_INC;
f += FRACT_INC;
f -= FRACT_MAX;
//m += 1;
i = 2;
timer0_fract = f;
//timer0_millis = m;
for (j=0; j<DELAY_SLOTS;j++){
if(isr_countdowns[j] > 0){
isr_countdowns[j] = isr_countdowns[j] - i;
void timer0_isr_init(void) {
sbi(TCCR0A, WGM01);
sbi(TCCR0A, WGM00);
#endif
sbi(TCCR0, CS02);
sbi(TCCR0, CS01);
sbi(TCCR0, CS00);
sbi(TCCR0B, CS01);
sbi(TCCR0B, CS00);
sbi(TCCR0A, CS01);
sbi(TCCR0A, CS00);
#else
#endif
sbi(TIMSK, TOIE0);
sbi(TIMSK0, TOIE0);
#else
#endif
// check if the time in a specific slot expired
uint8_t check_delay(uint8_t slot)
if (slot >= DELAY_SLOTS) return TRUE; //protection against user input error
cli();
if (isr_countdowns[slot]<=0){
SREG = oldSREG;
return TRUE;
SREG = oldSREG;
return FALSE;
//set the duration of a delay (in milliseconds) in a specific slot
void set_delay(uint8_t slot, uint16_t ms_time){
if(slot >= DELAY_SLOTS) return; //protection against user input error
cli();
isr_countdowns[slot] = ms_time;
SREG = oldSREG;
void main(void) {
// setting (LED) pins as outputs
sbi(DDRD, 5);
sbi(DDRC, 6);
sbi(DDRC, 7);
// init the non_blocking delays
timer0_isr_init();
sei();
// set delays in milliseconds for every LED
set_delay(0, 250);
set_delay(1, 500);
set_delay(2, 750);
while(1){
if(check_delay(0)){
tbi(PORTD, 5);
set_delay(0, 250);
if(check_delay(1)){
tbi(PORTC, 6);
set_delay(1, 500);
if(check_delay(2)){
tbi(PORTC, 7);
set_delay(2, 750);
Both programs do the same. The code-size results, using the latest ATMEL toolchain, are as follows (I think that the majority of JAL users are maniacs regarding their code size, me included):
Using millis():
Code: [Select]
Device: atmega644p
Program:     606 bytes (0.9% Full)
(.text + .data + .bootloader)
Data:         25 bytes (0.6% Full)
(.data + .bss + .noinit)
Code: [Select]
Device: atmega644p
Program:     516 bytes (0.8% Full)
Data:         11 bytes (0.3% Full)
cr0sh
Quote
There's one main reason for this when it comes to the Arduino:
Portability.
Most of the waste of microcontroller resources is there because the Arduino system was designed so that you could (in general) write a single program, and expect it to work the same across a variety of different microcontrollers in the same "family" - without needing to re-write the code. At least, that's the idea; it probably has problems in practice depending on what pins you are using, which microcontroller you are using, and what the code was originally written for. I would imagine though, that for the most part, it works better than the alternative (which would necessitate a re-write and a higher knowledge of the hardware than what the userbase the Arduino is aimed at would have).
Fortunately, you found a way around this (so many pooh-pooh the Arduino as being a toy, when in fact it isn't and can be used with a regular AVR development toolchain if you are willing to put in the work of setting it up). Just don't expect your code to be very portable (the code you presented may or may not be - I don't know this for certain - but in general, when not using the Arduino libraries, you have to be more careful and mindful to make your code portable).
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
funlw65
#3
Jun 21, 2013, 05:01 am Last Edit: Jun 21, 2013, 05:14 am by funlw65 Reason: 1
Well, there are solutions regarding to portability. I mean, you can use a C library designed to support many more microcontrollers, as is ASF from Atmel. I forked libarduino project of Mike and I can use same code (not the one I presented, which is made for Sanguino, without portability in mind) on many ATmega devices and some Arduino boards: http://atmega-clib.googlecode.com. Is possible and Arduino team should consider preparing the people to advance on the next step (the users are evolving anyway). libarduino is a good example. Unfortunately, no updates from a long time.
But again, nothing against Wiring language and what Arduino means.
P.S. No problem for me to make the presented code portable... just inserting some #if 's . millis() is already written by the Arduino team with portability in mind, and slotted, non-blocking delays is based on millis() code - already portable. The non-portable part of the code was the "pinout" - there comes the conditional compiling...
nickgammon
Quote
The compiler itself usually does an excellent job of generating tight code, and the linker throws away almost everything that isn't actually used.
However it is true that the default libraries, being nice and general, generate more code than they might. However you don't have to use them. You can still make a small program inside the Arduino IDE. For example:
Code: [Select]
int main ()  { }
Program size (compiled for Uno):
Code: [Select]
Binary sketch size: 176 bytes (of a 32,256 byte maximum)
In any case it's only a waste if you need the program space for something else.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
funlw65
#5
Jun 21, 2013, 03:35 pm Last Edit: Jun 21, 2013, 04:19 pm by funlw65 Reason: 1
Code: [Select]
int main ()  { }
Code: [Select]
138 bytes if the IDE is using avr-gcc 4.7.3 as is on Linux Fedora19 (I told you, I am maniac)  :D
Quote
True.
nickgammon
Looks like most of the extra bytes are to do with initializing instances of classes. You would probably find that with a larger project the differences would be minimal.
funlw65
#7
Jun 22, 2013, 04:53 pm Last Edit: Jun 22, 2013, 05:35 pm by funlw65 Reason: 1
Excepting classes, printf function is another culprit in increasing the code size - alot. Some time ago I did another test between Arduino, Wiring and ATmegaCLib C library, and I avoided to use printf function, compiling an application with PCF8583.
In the following image, we have Arduino on the left, Wiring on the right, and Eclipse in background. For both Arduino and Eclipse I used gcc 4.7 and Wiring came with 4.3.5 version. You can see the resulted code size on each window.
This kind of analysis helps you chose the right tools, libraries, methods when you shrinkify your Arduino projects or go commercial.
comparison-wiring-language-and-c by funlw65, on Flickr
https://code.google.com/p/atmega-clib/source/browse/trunk/ATmega_PCF8583_Serial/main.c
nickgammon
First thing:
From what I can see of the code the Serial handling is wrong. You check for Serial.available being greater than 0 but then do multiple reads. Only one read is safe.
http://www.gammon.com.au/serial
Second thing:
Your code snippets appear to be doing the same idea in different ways. If the Arduino version did not use sprintf then it would be smaller too. Example:
Code: [Select]
volatile int day = 1, month = 2, year = 1998;
void setup ()
 Serial.begin (115200);
 char time [20];
 sprintf (time, "%d/%d/%d", day, month, year);
 Serial.println (time);
 }  // end of setup
void loop () { }
Code size (compiled for Sanguino):
Code: [Select]
Binary sketch size: 3,910 bytes (of a 63,488 byte maximum)
Doing away with sprintf (and looking neater as well):
Code: [Select]
#include <Streaming.h>
void setup ()
 Serial << day << "/" << month << "/" << year << endl;
 }  // end of setup
void loop () { }
Code size:
Code: [Select]
Binary sketch size: 2,774 bytes (of a 63,488 byte maximum)
I saved over 1100 bytes by not using sprintf. But you can do that in the Arduino IDE.
funlw65
#9
Jun 23, 2013, 05:08 am Last Edit: Jun 23, 2013, 05:37 am by funlw65 Reason: 1
I know, the read_write_time sketch example it comes with the Arduino Dallas library if I correctly recall... it suppose the configuration string was correctly introduced. I made my example after that, trying to reproduce it.
BTW, interesting forum software!
nickgammon
GoForSmoke
I don't see a real advantage of the slotted delays over what is done with Arduino now.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
nickgammon
I think GoForSmoke is right. This doesn't achieve a huge amount. For one thing, if the interrupt that fires every millisecond tries to do anything useful (like "do the task") then the task is "done" in the context of an ISR which means there are lots of things it can't do, like serial printing. Plus, interrupts are supposed to be short.
If the interrupt just sets a flag to show that a task needs to be done, you may as well just test for elapsed time in loop, what has the flag achieved?
http://www.gammon.com.au/blink
nickgammon
I did a small class a while back that encapsulates that idea. It just stores a start time in a class instance and you use a function call to find how much time has elapsed between then, and now, and if enough time has elapsed you can do something. You test for this in "loop".
http://www.gammon.com.au/forum/?id=11094
Example:
Code: [Select]
#include <Elapsed.h>
  pinMode (2, OUTPUT);
  pinMode (3, OUTPUT);
  }  // end of setup
static Elapsed t2, t3;
  if (t2.intervalMs () > 200)
    digitalWrite(2, !digitalRead (2));
    t2.reset ();
if (t3.intervalMs () > 500)
    digitalWrite(3, !digitalRead (3));
    t3.reset ();
}  // end of loop
GoForSmoke
I have gone as far as checking to see if millis() has changed before doing the whole elapsed time check because of how many times execution went through loop() in a msec, which was many (10 to 20) in one sketch.
It didn't make a lot of difference per loop but hey, it let my sketch waste time even faster!
