Topic: I used 5volts and 0(open) as digital inputs but i got problem with its outputs. (Read 733 times) previous topic - next topic
3kier
Hello Everyone!! im  novice in arduino i really need ur help..
i have 2 digital input pins(pin16 & pin17 actually i need 4)
just to test if it really gonna work.What i did is that
i just give 5volts or high to these pins as input data
but what happened there is that the 2 digitalOutput pins respectively
seems doesnt do to the conditions i gave, it seems it can affect the other condition..
Here is my code...
int sPin =16;
int sPin1 =17;
int ledPin7 =7;
int ledPin6 =6;
void setup(){
  pinMode(ledPin7,OUTPUT);
  pinMode(ledPin6,OUTPUT);
   pinMode(sPin,INPUT);
   pinMode(sPin1,INPUT);
void loop(){
  Serial.println(digitalRead(sPin));
  int val = digitalRead(sPin);
if (digitalRead(sPin) == LOW )
    { digitalWrite(ledPin7,HIGH);
  if (digitalRead(sPin1) == LOW )
    { digitalWrite(ledPin6,HIGH);
    digitalWrite(ledPin7,LOW);
    digitalWrite(ledPin6,LOW);
what i really want to do there is that,
   just have  4  inputs(that would be 5volts/0)
   and also give 4  outputs respectively..
i really need ur ideas, suggestions or any other alternatives guyz.. thnx
AWOL
You're not using the built-in pullups, so have you got external ones connected?
CrossRoads
Try changing these
to
   pinMode(sPin,INPUT_PULLUP);
   pinMode(sPin1,INPUT_PULLUP);
As the pins may be floating as AWOL suggests.
o_lampe
If you do it with the internal pullups, you might have to reverse your logic, because the input wouldn't change it's state, when you put it on 5V externally. You'd have to switch it to GND instead or use external pull-down resistors instead of the internal pullups.
BTW: the 'else' command is now only working for the lower 'if' routine:
Better put it that way:
