Topic: Android Bluetooth joystick (Read 313619 times) previous topic - next topic
kas
Jun 21, 2013, 09:17 am Last Edit: Jul 28, 2018, 10:48 am by kas
Edit:    **  Current Versions  **
         - Joystick bluetooth Commander:    V5.5
         - AndroTest.ino demo sketch:            V2.0
* New *
Code for espressif ESP32
Code for Parallax Propeller, in "C"
  (thanks twm47099)
Code for Parallax Propeller in "Spin"
  (thanks jonnyMac)
        - Samsumg Galaxy Tab 4 users,
please look here
scroll to the end of this message to get latest information
I developed an Android application that turns a smartphone into a virtual Bluetooth joystick.
The applications in the robotic field are endless: Home Automation, R/C cars, robotic arms and of course  balancing robots ;)
By default, the device transmits data every 200ms
Data format: [STX  X  Y  ETX]
example: [0X02  0X2A  0X30  0X03]
The application is available (for free 8)) here
From you smartphone, access Google Store and search for "Joystick bluetooth Commander"
This demo Arduino sketch will parse data on the serial monitor, and control the pin13 LED
Code: [Select]
// AndroLED V5
// Arduino test sketch for Joystick BT commander
// LED control for buttons + joystick echo to serial monitor
//    ** deprecated, please use AndroTest_V13.ino **
//    see reply #181
http://www.youtube.com/watch?v=jNiGa_gK2KU
The Hardware setup is rather straightforward, should you need additional info, just let me know
Enjoy
Edit:
Updated Arduino sketch,
set Baud rate to default 9600
removed softserial
For sketch upload, don't forget to disconnect board TX from Arduino D0
Edit2:
Joystick Bluetooth Commander Version 2.3 is now compatible with Android V3.X and V4.X (Honeycomb, Ice Cream Sandwich, Jelly Bean)
Edit3:
added   Serial.println("Bluetooth Commander simulation") in setup() for communication testing purpose
Edit4:
Joystick Bluetooth Commander Version 2.4
Four toggle buttons with visual feedback
Change Log and Arduino sketch modification: please refer to reply #51
Edit5:
Joystick Bluetooth Commander Version 2.5
Change Log: refer to reply #70
Edit6:
Joystick Bluetooth Commander Version 3.0
** major Upgrade **
Joystick Bluetooth Commander is now a full blown two way Bluetooth communication application
Arduino sends back a button status Byte and a user defined data Byte to be displayed on the phone/tablet screen (Bot battery level is a nice candidate)
Communication protocol has changed
Joystick data is now transmitted as an integer = 2 Bytes (Most Significant Byte + Less Significant Byte)
<STX  MSB-X  LSB-X  MSB-Y  LSB-Y  ETX>
Your V2.5 Arduino sketch needs to be modified for V3.0
See full change Log at reply #74
Updated demo Arduino sketch at reply #90
Edit7:
Fixed link to Balancing robot for dummies
Edit8:
New Arduino demo sketch (V10.1)
Improve decoding algorithm, see reply #98
Edit9:
Joystick Bluetooth Commander Version 3.1
Maintenance release, see reply #100
Edit10:
New Arduino demo sketch (V10.3)               << for Artouste   ;)
Bug fix, see reply #129
Edit11:
Joystick BT Plus  has been released with 6 buttons and 4 data bytes
The actual number of buttons and data fields is adjustable within the Option menu
Fields and buttons labels are fully customizable
See reply #165
Edit11:
Detailed info re Communication Protocol (send and receive)
See reply #154 & #156
Edit12:
Joystick BT Plus (6 buttons, 3 datafields)
and
Total RC Commander (video from IP camera)
are now available see reply #177
More info here
Edit13:
Joystick BT Plus (up to 6 buttons, up to 3 free format datafields) is now
               - Joystick bluetooth Commander V4.0 -
and is available on Google Play as a free upgrade.
To allow text datafield, Communication Protocol has changed
Please use and adapt AndroTest_V13.ino demo sketch to your own needs
** deprecated, please use AndroTest_V14.ino **
See reply #181
Edit14:
Communication Protocol for Joystick bluetooth Commander V4.x and Total RC Commander
now fully documented
See reply #188
Edit15:
A video showing tank control using Total RC Commander. has been posted in the Exhibition Section
More info here
Edit16:
AndroTest_V14.ino
This updated sketch features optimized timing and better transmission error management
Make sure your BT board is set @57600bps
(or modify sketch accordingly)
See reply #210
Edit17:
AndroTest_V141.ino
See reply #212
Edit18:
BT boards types and configuration tools
See reply #227
Edit19:
Joystick bluetooth Commander Version 5.0 has just been published on Google Play
** Communication protocol has changed **    see reply #252
- Change log:   see reply #259
- Demo sketch: AndroTest V2.0      see reply #256
Edit20:
Joystick bluetooth Commander Version 5.2 now on Google Play
- Change log:   see reply #292
Edit21:
For my new project, I am testing a robotic claw using Joystick BT Commander
Edit22:
Good new, classic Bluetooth feature is now available for ESP32
I have ported the basic Arduino demo sketch (AndroTest_V20_POSTED.ino) to this super platform
No wiring, no software setup, nothing !!
just upload to ESP32 and enjoy        see  reply #914
End of technical support
I have been supporting this project for five years, this was an exciting experience
I have since moved to other projects and it's now time for me to retire
All possible questions have been answered in this thread, just read it  ;)
Feel free to use this thread on a peer to peer basis to share your experience
Please no more PM's
Thanks again for your interest and good luck for your projects
kas
#1
Jun 24, 2013, 10:39 am Last Edit: Jun 24, 2013, 08:22 pm by kas Reason: 1
I posted a pan/tilt project based on Joystick Bluetooth Commander, in the Robotic Section
jeffmorris
I have Samsung Galaxy Tab 7" tablet and Arduino Uno. The X and Y values on the tablet screen don't display the position of the joystick and nothing is displayed on the serial monitor. How can I fix the problem?
kas
#3
Jun 24, 2013, 08:15 pm Last Edit: Jun 24, 2013, 08:23 pm by kas Reason: 1
Bluetooth applications are difficult to debug in Eclipse IDE, as Virtual Devices do not emulate Bluetooth activity
Actual debugging has to be made on a specific real device (Sony Xperia Mini)
Quote
what is your tablet API level and display resolution ??
Quote
Make sure that options are as follow:
Data Range:   -50 to +50
Data display:    Joystick position
Data format:   STX and ETX
Are the buttons and the "not connected" string displayed on the tablet screen ??
Does the Joystick actually move when touched??
does it produce haptic feedback when this option is selected ??
Quote
Your Bluetooth serial board may be still configured @9600BPS
please adjust  mySerial.begin(57600) to your specific Baud rate
Also make sure that your Bluetooth serial board is already paired with your tablet
finally uncomment
Code: [Select]
//        Serial.print(i);  Serial.print(": ");  Serial.println(cmd[i]);
and let me know the outcome
@all
My specific configuration is working flawlessly
Should you have installed this application on a different device, please post feedback
kas
#4
Jun 26, 2013, 12:02 pm Last Edit: Jun 28, 2013, 02:00 pm by kas Reason: 1
@jeffmorris
I beleave you are facing two non related problems
- Communication with your BT card (your task)
check pairing, Baud rate, connection to Arduino (Menu/Connect)
I use a JY-MCU rev1.05 board
Onboard LED should be flashing when powered and gets solid red when connected
Connect TX board to RX (D0) Arduino
Above Arduino sketch has been updated to V5 (removed SoftwareSerial)
- UI display on tablets (my task)
I will publish today on Google Play a new version insuring compatibility with tablets
Edit: Joystick Bluetooth Commander V2.2 is now available
Please make sure that application is configured as follow:
- Data Range  -50 to +50
- Data display   Joystick position
- Data format STX and ETX
- Refresh interval   100ms
- Button1 data to send    '1'
- Button2 data to send    '2'
jeffmorris
The screen shown on the second screenshot at https://play.google.com/store/apps/details?id=org.projectproto.btjoystick&feature=search_result#?t=W251bGwsMSwxLDEsIm9yZy5wcm9qZWN0cHJvdG8uYnRqb3lzdGljayJd doesn't show up. How can I fix this?
kas
#6
Jun 29, 2013, 06:32 pm Last Edit: Jun 29, 2013, 06:44 pm by kas Reason: 1
Quote
Can you move the joystick ??
Are the data now displayed on the tablet screen ??
Quote
The menu is displayed when pressing the hardware menu button at the bottom of your tablet
Can you access it ??
You need to enter this menu to establish a Bluetooth communication
Please let me have more detailed information
I will post a new version including a "reset configuration" option
The initial configuration should work right out of the box with the above Arduino sketch
jeffmorris
I can't find the hardware menu button at the bottom of the tablet screen. When I move the joystick, the X and Y values at the bottom left corner of the screen change. A red message at that corner says "Not Connected".
kas
#8
Jun 29, 2013, 09:09 pm Last Edit: Jun 29, 2013, 10:27 pm by kas Reason: 1
Is it your model?
What happens when you launch Joystick Bluetooth Commander and press the button on the left ?
EDIT
Not sure this is the right one   :smiley-slim:
The option button is this one (red circle)
Can somebody jump in and explain how to access applications menu or options on the Galaxy Tab tablet ??
kas
#9
Jun 30, 2013, 11:52 am Last Edit: Aug 19, 2013, 09:56 pm by kas Reason: 1
I now realize that beginning with Android 3.0 (API level 11), Android-powered devices are no longer required to provide a dedicated Menu button  :smiley-sad-blue:
Joystick Bluetooth Commander Version 2.3 now adds full compatibility with Android 3.X  and 4.X
The menu that allows BT connection can be accessed though the added 'action overflow button' (red square)
some other devices have a different icon at bottom left
thanks for bringing this point to my attention, sorry for being GingerBread centric
The application has been tested and is fully operative on my son's 7" Samsung Galaxy tablet (jelly beans)
Thanks to Julian for his contribution  ;)
jeffmorris
The Samsung Galaxy Tab 7.0 Plus has display resolution of 1024x600.
http://www.samsung.com/global/microsite/galaxytab/7.0/spec.html?type=find
kas
OK
Just install Version 2.3, and let me know the outcome.
You should now have a Menu button available for establishing connection.
Next step is to get your BT board connected. With a JY-MCU type, the on board LED should change from blinking to solid red
jeffmorris
I think that version 2.3 works but I don't see anything on the Serial Monitor after changing #define DEBUG from false to true. I can connect my tablet to the Arduino UNO board with Bluetooth module but the Pin 13 LED doesn't work when I touch the buttons next to the "joystick". The values change when I move the "joystick". The LEDs on the Bluetooth module changed from flashing red to non-flashing green.
kas
OK
Please check those 3 points:
1) Arduino sketch
Add
Code: [Select]
Serial.println("***");
as the last line of setup()
Please confirm the stars are displayed on the serial monitor
D0 should be disconnected to allow sketch upload
(and reconnected afterward  ;))
2) Hardware connection
please refer to message #4
Only 3 wires
5V to 5V
GND to GND
TX board to D0 (Arduino RX)
3)BT board Baud rate
Some BT boards default to 19200BPS
Please adjust "Serial.begin(9600)" and Serial Monitor Baud rate accordingly
Should you require it, I will upload an Arduino sketch for checking BT board Baud rate and/or setting a new value. This sketch also insure that the BT board is OK
jeffmorris
Please send me the sketch that for checking and setting Bluetooth baud rate. I added
as the last line of setup() and the stars show up on the serial monitor.
