Topic: Android Bluetooth joystick (Read 320350 times) previous topic - next topic
kas
Comment from Google Play:
Quote
Muy buena aplicacion Aplicacion sencilla y de fácil uso, el código facilitado para arduino es muy útil.
Espero más versiones con más botones para seguir trabajando con ello.
Thanks for the nice comments
Regarding additional buttons, I have mixed feelings as my Xperia mini screen is allready cluttered
On the other hand, a screen tablet is another story, with a lot of space (see reply #28)
May be an option to place additional buttons according to the available real estate
Road map for the next versions:
- remove Data range -10 to +10 (useless)
- add Data range -100 to +100 for increased resolution
- add Calibration screen for "Zero" position offset
My Google Play downloads are in the 100 - 500 category
Please let me have additional feedback
- Android device
- Android version
- suggested new features
TIA
oric_dan
I guess I've already mentioned it, but to me, having a couple more on/off buttons would really be nice. You'll notice a guy on another thread here wanting an Android app to "control relays".
One way to implement this with little additional screen real estate is fork the current on/off buttons into 2 separate on/off functions, and simply change the button color/etc to indicate last msg state. Actually, on your screen in post #0, I'd think you'd have room for at least 4-6 buttons without too much interference. Just a thought.
[I'm still looking at Android dev, but currently off trying to get my ethernet shield to do tweets and talk to xively, :-)].
kas
#47
Jul 20, 2013, 02:26 pm Last Edit: Jul 20, 2013, 02:27 pm by kas Reason: 1
OK, OK...
What's about this layout
Four toggle buttons with visual feedback
Relays 2 and 3 are supposed to be energized
Rafolas
Hi! I have liked your application because I allow me to control motors through bluetooth. I use various dispositives to use program: mobile and tablet. The mobiles that we uses are Samsung Galaxy S2 (Ice Cream Sandwich) and  S3 (Jelly Bean), and the tablets are Samsung Galaxy Note 10.1 (Jelly Bean) and Nexus 7 (Jelly Bean).
I like the idea of you to increase the range of -100 to +100 to allow better control. And it's okay to add more buttons to take further action with the robot.
If I have any ideas for your design and can be useful to me I write it on the forum.
A greeting! and sorry for my English is not very good  =(
oric_dan
#49
Jul 20, 2013, 08:42 pm Last Edit: Jul 20, 2013, 08:45 pm by oric_dan Reason: 1
That's great, kas, exactly what I was thinking about, :-).
You might make it so, in the options menu, you can select momentary activation or toggle on the switches [ha - it never ends, people always want more, each solution breeds a new idea, LOL].
kas
#50
Jul 20, 2013, 09:29 pm Last Edit: Jul 20, 2013, 09:31 pm by kas Reason: 1
Hi Rafolas, welcome to the forum  :)
Thanks for taking the time to register and to send your very first post in this thread
Your feedback is (and will be) appreciated
@oric_dan
Quote
In Android, Buttons and ToggleButtons are different beast... :smiley-roll-blue:
For the moment, I am creating the option menu for displaying zero, two or four buttons on the screen
kas
#51
Jul 21, 2013, 11:04 am Last Edit: Jul 30, 2013, 06:05 pm by kas Reason: 1
I will post Joystick Bluetooth Commander V2.4 on Google play later today
Change log:
- Display up to four toggle buttons with visual feedback
- Button visibility option setting (0 - 2 - 4)
- added Timeout count "every 1000 intervals" to support new low refresh intervals
- default refresh interval set to 50ms
- removed buttons data option setting (not relevant anymore)
New buttons protocol:
Button1_ON   < STX  '1'  ETX >
Button1_OFF  < STX  '2'  ETX >
Button2_ON   < STX  '3'  ETX >
Button8_OFF  < STX  '8'  ETX >
The original Arduino setLED() function should be modified:
Code: [Select]
void setLED(int LEDstatus)  {
 switch (LEDstatus) {
   case '1':
     Serial.println("Button_1: ON");
     // your code...
   case '2':
     Serial.println("Button_1: OFF");
     // your code...
   case '3':
     Serial.println("Button_2: ON");
     // your code...
   case '4':
     Serial.println("Button_2: OFF");
     // your code...
   case '5':
     Serial.println("Button_3: ON");
     // your code...
   case '6':
     Serial.println("Button_3: OFF");
     // your code...
   case '7':
     Serial.println("Button_4: ON");
     // your code...
   case '8':
     Serial.println("Button_4: OFF");
     // your code...
Disclaimer:
See reply #36
@ oric_dan
Please let me have a tablet screenshot similar to reply #28
Enjoy
EDIT: Done!
liuzengqiang
Looks great! Will the source code of the joysticker commander be open at some point for use to learn from?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
kas
#53
Jul 22, 2013, 08:21 am Last Edit: Jul 22, 2013, 08:54 am by kas Reason: 1
Quote
I will definitely make the source code available
Need some time to polish it a bit
Inspiration rarely comes from the Vacuum  ;)
Please refer to the "About" section of the Application menu
The code uses a mobile-anarchy widget combined with the classical BluetoothChat Android SDK example
liuzengqiang
Awesome. I have several times attempted to program in android system but the barrier is too high for me. I almost never program any GUI on any OS except for occasional Java popup and dialog type of simple GUIs. If at some point in the future I get your code, I can learn from it. Thanks for deciding to share the code.
oric_dan
You guys are funny. 2 little blue men, ;-).
liuzengqiang
There are more of us. Have you looked into the mirror today? ;)
kas
Hi Liudr
Quote
A Bluetooth project is probably not the coolest way to start learning Android :smiley-roll-blue:
There is a lot of video tutorials on Youtube starting from "Hello Word" type
applications and then, gradually, following the (rather steep) learning curve
You will quickly find that Android and Arduino live well together
Please see reply #31
Eclipse IDE is definitly the best tool for serious development
By the way... nice blog http://liudr.wordpress.com/
liuzengqiang
Thanks kas! I have a stack of books on unix. It's never easy to learn to program on a new operating system but if I can hack your program to do a few things (or maybe just use your program), I think I will motivate myself to get a few books on android. At the moment raspberry pi is pulling me in so I may have to wait to learn the android.
kas
#59
Jul 25, 2013, 08:59 pm Last Edit: Jul 25, 2013, 09:01 pm by kas Reason: 1
Quote
...but if I can hack your program to do a few things (or maybe just use your program), I think I will motivate myself to get a few books on android
If you really can't wait, send me a PM with your email address  ;)
