Topic: How would I make this if statement? (if somehting is within x amount?) (Read 9003 times) previous topic - next topic
XOIIO
I was just wondering how I would make an if statement like this, for measuring temperature, I want an indicator when it has stabilized, so if the temperature is withing + or - .20, then the if statement would continue. How would I do this? I know that I'll need to set a variable that changes so basically it would be if current temp is within plus or minus .20 of the last temp then it would do whatever I needed.
AWOL
Think about the arithmetic you have to perform to make this decision yourself.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
XOIIO
well I know how to do it with more than one line, I was just hoping there was a way to do it all in one if statement, instead of two like this.
  if (celsius == lasttemp + .20){
    if (celsius == lasttemp - .20){
      digitalWrite(13, HIGH);
else {
  digitalWrite(13, LOW);
JB_AU
Amateurs built the ark, Professionals built the Titanic
XOIIO
whoops, that should actually be this.
  if (celsius == lasttemp + .20) {
    if (celsius == lasttemp - .20) {
      else {
I'll check out boolean
Arrch
Code: [Select]
How can celcius be equal to two different values at the same time?
I think you're looking for something like this:
Code: [Select]
if ( (celcius >= lasttemp - 0.20) && (celcius <= lasttemp + 0.20) )
AWOL
XOIIO
Code: [Select]
Code: [Select]
Ahh, that does make more sense, I guess that's what you get for staying upt oo long, thank you.
Also, I didn't know about that && thing, that's gonna be usefull.
AWOL
Quote
So is abs.
XOIIO
hmm, now I've got to work on scripting this right. If I have this section at the start of the script then it doesn't turn the LED on. If I have it at the end the LED stays on permanently. hmmm
  if ( (celsius >= lasttemp - 0.2) && (celsius <= lasttemp + 0.2) ) {
  else {
Arrch
Start of what? End of What? All you've posted is snippets.
XOIIO
ahh true. Here's the whole thing.
Code: [Select]
#include <OneWire.h>
#include <LiquidCrystal.h>
OneWire  ds(10);  // on pin 10 (a 4.7K resistor is necessary)
LiquidCrystal lcd(6, 7, 5, 4, 3, 2);
float lasttemp;
void setup(void) {
  pinMode(13, OUTPUT);
  lcd.begin(8, 2);
  lcd.setCursor(0,0);
  lcd.print("STARTING");
  lcd.setCursor(0, 1);
  lcd.clear();
void loop(void) {
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
  float celsius, fahrenheit;
  if ( !ds.search(addr)) {
    Serial.println("No more addresses.");
    ds.reset_search();
    delay(250);
    return;
  Serial.print("ROM =");
  for( i = 0; i < 8; i++) {
    Serial.write(' ');
    Serial.print(addr[i], HEX);
  if (OneWire::crc8(addr, 7) != addr[7]) {
    Serial.println("CRC is not valid!");
    return;
  // the first ROM byte indicates which chip
  switch (addr[0]) {
  case 0x10:
    Serial.println("  Chip = DS18S20");  // or old DS1820
    type_s = 1;
  case 0x28:
    Serial.println("  Chip = DS18B20");
    type_s = 0;
  case 0x22:
    Serial.println("  Chip = DS1822");
    type_s = 0;
  default:
    Serial.println("Device is not a DS18x20 family device.");
    return;
  ds.reset();
  ds.select(addr);
  ds.write(0x44, 1);        // start conversion, with parasite power on at the end
  delay(1000);     // maybe 750ms is enough, maybe not
  // we might do a ds.depower() here, but the reset will take care of it.
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Read Scratchpad
  Serial.print("  Data = ");
  Serial.print(present, HEX);
  Serial.print(" ");
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = ds.read();
    Serial.print(data[i], HEX);
    Serial.print(" ");
  Serial.print(" CRC=");
  Serial.print(OneWire::crc8(data, 8), HEX);
  // Convert the data to actual temperature
  // because the result is a 16 bit signed integer, it should
  // be stored to an "int16_t" type, which is always 16 bits
  // even when compiled on a 32 bit processor.
  int16_t raw = (data[1] << 8) | data[0];
  if (type_s) {
    raw = raw << 3; // 9 bit resolution default
    if (data[7] == 0x10) {
      // "count remain" gives full 12 bit resolution
      raw = (raw & 0xFFF0) + 12 - data[6];
  else {
    byte cfg = (data[4] & 0x60);
    // at lower res, the low bits are undefined, so let's zero them
    if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
    else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
    else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
    //// default is 12 bit resolution, 750 ms conversion time
  celsius = (float)raw / 16.0;
  fahrenheit = celsius * 1.8 + 32.0;
  Serial.print("  Temperature = ");
  Serial.print(celsius);
  Serial.print(" Celsius, ");
  Serial.print(fahrenheit);
  Serial.println(" Fahrenheit");
  lasttemp = celsius;
  lcd.setCursor(0, 0);
  lcd.print(celsius);
  lcd.print(" C ");
  lcd.print(fahrenheit);
  lcd.print(" F ");
  Serial.print(lasttemp);
      digitalWrite(13, HIGH); }
      else {
I've tried using a variable to set the led state, but that got the same result.
I kind of know why it's doing it but I can't figure out a solution.
XOIIO
oh wait, maybe if I throw that whole thing into a while statement it will work.
hmm, well that didn't work, I'll try another way but not sure if that will work either.
Arrch
Code: [Select]
 lasttemp = celsius;
     else {
At the time that it gets to the if statement, lasttemp will be equal to celcius. That means that celcius - lasttemp will be equal to 0 every time. 0 is between -0.2 and 0.2, so how can you expect anything other than the if statement always being true?
XOIIO
Code: [Select]
 lasttemp = celsius;
     else {
Yeah, the problem is that that is when the Celsius actually has a value. I've tried putting this section at the top of the loop, but it doesn't do anything since it has been reset.
Also, that while loop theory didn't pan out.
