Topic: How to format a Get Request (Read 968 times) previous topic - next topic
James-Brown
I have an external server running MySQL. I have installed a php script that, when accessed from HTTP will deliver data from one of the tables. It works fine from a browser:
Code: [Select]
http://www.seti.net/php/getEvents.php
I cannot figure out how to send this command from Arduino. I have the EthernetClient library working and can access Google as in the example.
When I send this command through the client:
Code: [Select]
client.println("//GET /php/getEvents.php HTTP/1.0");
the server returns:
Code: [Select]
</head><body>
<h1>Method Not Implemented</h1>
<p>GET to /php/getEvents.php not supported.<br />
What is the correct way to format a GET in Arduino?
wildbill
I use a GET to send a temperature to my web server. Note the lack of HTTP version and the additional blank line after the get - not sure whether the difference is important but it works:
Code: [Select]
void  SendTempToServer()
char GetRequest[80];
if (client.connect(server, 80))
  sprintf(GetRequest,"GET /cgi-bin/Arduino.cgi?Reading=%s&arduino_id=23&sensor_id=1",Temperature);
  //Serial.println(GetRequest);
  client.println(GetRequest);
  client.println();
SurferTim
Do not use the double slash preceding the GET.
Code: [Select]
// change this
// to this
client.println("GET /php/getEvents.php HTTP/1.0");
And your web host uses virtual hosting. Insure you send the Host parameter. I use HTTP/1.1 for that.
Code: [Select]
client.println("GET /php/getEvents.php HTTP/1.1");
client.println("Host: www.seti.net");
client.println("Connection: close\r\n");
James-Brown
Cool - That does work.  Thank you very much.
One last.  Where can I go to learn why it works?  Do you have a good reference or a Google subject I can read?
Thanks again.
SurferTim
The correct format on the GET line is important for obvious reasons. The virtual server is a bit more obscure. Here is a wiki article on virtual hosting.
http://en.wikipedia.org/wiki/Virtual_hosting
A Google search works good for that if you need more info.
James-Brown
Cool again surfer.  It looks like I have to go learn about HTTP Headers - Right?
SurferTim
Right, and the ability to recognize a virtual server so you know what header parameters are required.  :)
Here is how I determined your server uses virtual hosting. In the address bar of your browser
http://www.seti.net
and you get your home page.
In nslookup
Code: [Select]
C:\Documents and Settings\user>nslookup www.seti.net
Server:  ip68-105-28-16.at.at.cox.net
Address:  68.105.28.16
Non-authoritative answer:
Address:  205.134.250.170
Aliases:  www.seti.net
Then try that ip in your web browser
http://205.134.250.170
You will get your web hosting service page
inmotionhosting.com
James-Brown
#7
Jun 22, 2013, 04:39 pm Last Edit: Jun 22, 2013, 04:46 pm by James-Brown Reason: 1
Surfer - learning a lot but one last and then I'll go away and study.
I also have on that same server a php script that sets the database.  It can be called from a browser like this:
Code: [Select]
http://www.seti.net/php/setEvent.php?pixel_ID=1212
What is the equivalent code for the arduino to do this?
SurferTim
Code: [Select]
client.println("GET /php/getEvents.php?pixel_ID=1212 HTTP/1.1");
Here is my client code.
http://playground.arduino.cc/Code/WebClient
I use a character array to pass the page and those parameters like this:
Code: [Select]
    sprintf(pageAdd,"/php/getEvents.php?pixel_ID=%u",totalCount);
    if(!getPage(server,serverPort,pageAdd)) Serial.print(F("Fail "));
hegdekir
Surfer,
As you explained, after getting the hosting service page, how to get the header parameter i have to pass ?
Kiran
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
