Topic: Diode in SERIES with Relay Coil (Read 1 time) previous topic - next topic
mech_eng
Jun 22, 2013, 05:00 pm Last Edit: Jun 22, 2013, 05:03 pm by mech_eng Reason: 1
What would be a good diode to prevent a NO relay from closing when reverse polarity is applied to a circuit via a drunk wiring said circuit by placing a diode in series with the coil, assuming relay current is less than 300mA?
Note: This is NOT for back EMF protection, just trying to prevent frying a SABERTOOTH if  wired up backwards and flip on the switch which controls a relay
Grumpy_Mike
Use a series diode rather than a parallel one. To minimise voltage drop use a Shockley diode.
http://en.wikipedia.org/wiki/Shockley_diode
Henry_Best
Did you really mean a Shockley diode or did you mean a Schottky diode?
Grumpy_Mike
OK
http://en.wikipedia.org/wiki/Schottky_diode
I am dyslexic.
PeterH
I haven't got my head around the circuit that this would be protecting, but if you want to arrange that a solenoid can be operated by a forward voltage but not a reverse voltage then a series diode seems to me to be a sensible way to do it.
I only provide help via the forum - please do not contact me for private consultancy.
Henry_Best
OK
I am dyslexic.
So is my son, so you have my sympathy.
