Topic: How does wheel size affect speed??? (Read 6609 times) previous topic - next topic
drewdavis
I have a question about wheel size.  If you have two robots, one with 2inch wheels and one with 3 inch wheels, and they are build exactly the same besides the wheel size which one will be able to achieve a faster possible speed? Also, which one will be able to produce more torque or will they both be the same? My guess it that the one with larger wheels will go faster and the one with smaller wheels will have more torque but I would like to double check.
Thanks!
robtillaart
#1
Jun 22, 2013, 07:18 pm Last Edit: Jun 24, 2013, 07:04 am by robtillaart Reason: 1
first order math:
the speed is # revolutions * circumference of wheel.
circumference = PI * R^2 /4
so the 3 inch wheel will be 9/4 == 2.25 as fast as the 2 inch wheel.
update:
circumference = PI * R / 2
so the 3 inch wheel will be 3/2 == 1.5 as fast as the 2 inch wheel.
second order math:
The 3 inch wheel is a bit heavier so it takes a bit more energy to move. (ask a MechEng for the details)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
drewdavis
aarondc
robtillaart
Hi Aarondc,
my mistake you are 100% right, I hope it wasn't a school assignment ;)
I'll update my post
Rob Tillaart
aarondc
Hi Aarondc,
I'll update my post
I hope it was ;)
robtillaart
Rob Tillaart
drewdavis
It wasn't for a school assignment (i'm not that lame). I'm building a sumo bot using Arduino and I'm trying to chose the best wheels. Assuming that the same motor was used would the smaller wheels have more torque to push the other robots.
Thanks!
aarondc
Thanks!
Was just messin' ;-)
My understanding is that torque is measured as force x distance. foot-pound, oz-inch, kg-cm, Nm are examples of units you will often see.
The torque of the motor is a constant at a constant voltage / current, so as the distance increases, the force is reduced.
eg: 20 kg-cm at 1 cm affords 20kg of force. At 2 cm, you're going to max out at 10kg. Assuming constant current.
So the smaller wheels should afford you more force at the circumference of the wheel, but the torque is the same.
drewdavis
aarondc
To answer your OP: force will be higher but speed lower. Something to keep in mind when designing a battle bot - do you want speed for agility, or a slower bot with a bit more grunt?
mech_eng
#11
Jul 01, 2013, 05:41 am Last Edit: Jul 01, 2013, 05:50 am by mech_eng Reason: 1
A larger tire will require more torque output from the motor, this will cause the motor to slow down for a given voltage which in turn increases power consumption by said motor.
How much the motor slows down will determine wether the bot will move faster or slower for a given wheel size.
EDIT:
In other words you can oversize a tire when trying to get more speed out of a bot and actually slow down the bot
Speed = diametertire*pi*angular_velocitytire
If angular_velocity decreases more than the diameter increases then speed will decrease, the other way around speed increases
