Topic: Lcd backligth problem (Read 806 times) previous topic - next topic
omereris
Hello I bougt 16X2 Blue Lcd .
I write code to arduino
Code: [Select]
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
 // set up the LCD's number of columns and rows:
 lcd.begin(16, 2);
 // Print a message to the LCD.
 lcd.print("hello, world!");
 // set the cursor to column 0, line 1
 // (note: line 1 is the second row, since counting begins with 0):
 lcd.setCursor(0, 1);
 // print the number of seconds since reset:
 lcd.print(millis()/1000);
?t's worked . But after 1 hour  I try .Lcd write hello, world! , Lcd s backlight not worked .
Why backlight didnt work
Grumpy_Mike
Does it work now? Or did it only work for the first hour?
If it is now broken was there a current limiting resistor in line with the back light?
You could have burnt it out.
unexpectedly
If it was an assembled shield, there are circuit layout problems with those. Google 16x2 backlight pwm and you'll probably find what I'm talking about. I just turned mine off...
Chris
