Topic: Leonardo keyboard leds emulation? (Read 11046 times) previous topic - next topic
anv
I am trying to create an USB keyboard controller with an Arduino Leonardo, but I can't find the way to emulate the keyboard leds. The PC sends the leds status to the keyboard but the Keyboard object on Arduino seems not to have any read function or any way to get the leds status.
PaulS
Quote
What LED and what status are you talking about? Shift lock, num lock? If so, didn't YOU send that information to the PC?
anv
#2
Jun 23, 2013, 02:31 pm Last Edit: Jun 23, 2013, 02:35 pm by anv Reason: 1
In the very very old XT keyboards, the num lock/caps lock/scroll lock status where sent only from keyboard to PC. Xt keyboards didn't receive info from the PC. But since many years with the AT keyboards, the communication is bidirectional, then you can connect two keyboards to the PC and hitting num lock in one affects the led status in all keyboards. Then, you can change the caps/scrool/num lock statys by software and this status is shown in the leds. Remember that keyboards does not send "letters" to the PC; it sends row/column of the key. Caps lock key is only another key with it's own row/column scan code and hitting it not necessarily will cause the caps lock led to get on or off. It is controlled by software in the PC.
UKHeliBob
Your original posting made no mention of a second keyboard, only the one being emulated by the Leonardo, hence the comment that as you were setting the Shift lock/Num lock status using the Arduino you had sent the status to the PC and did not need to receive it back.
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
anv
It does not matter how-many keyboards have you connected to the PC. The system is made in a way that allows many keyboards, then, the lock status is managed by the operating system and NOT by the keyboard. Then, the leds are controlled by the PC software and NOT by the keyboard itself. When you press caps lock, it does not turns on the caps lock led. The heyboard send the scan code (row/column) to the PC. The PC software changes the status of a flag and sends back to the keyboard the command for tuning on or off the led. The led status is not decided by the keyboard chip: it is completely controlled by the PC's operating system. Then, the keyboad chip must be able to receive controls from the PC... what seems to be lacking in Arduino HID implementation...
PaulS
Quote
It's open source. Quit whining and add it, if you need it.
anv
Quote
Of corse, just now I am checking the code. But first I wanted to ask if there where some way of doing it without modifying the libraries.
hartmut_holzgraefe
Did you succed in this? I added support for USB keyboard LED reports myself over the weekend, maybe this is still of interest to you ...
PaulDavis
The LED patch by hartmut_holzgraefe worked great for my project!
I've got a 20 year old Maxiswitch keyboard whose controller board died and I thought it would be a good project to replace the original Intel 8085 chip with an Arduino.  This is a 124 key keyboard with extra left side function keys etc.
I used a Sparkfun Pro Micro arduino and my program does all the keyboard row and column scanning mapping into the correct HID keyboard codes.  Thanks to the patch to the USB library, the shift/num/scroll lock LEDs work too.  Plus thanks to the Arduino, it is now a USB keyboard instead of the ancient AT style.
koogar
#9
Feb 19, 2014, 11:58 pm Last Edit: Feb 20, 2014, 02:20 am by koogar Reason: 1
Hi guys,
Could anyone explain how to install the "The LED patch by hartmut_holzgraefe"
I am not familiar with .diff   patchs , but I guess I would need the original to see the difference to alter the files
or could someone post their patched  USAPI.h  and HID.cpp ?
I have been looking for an example all night  :~,  so I could modify it to show a "MUTE" LED
http://www.usb.org/developers/devclass_docs/Hut1_12v2.pdf
Page 61
section 11   LEDPAGE(0x08)
09 Mute LED
Thanks in advance
Rupert
anv
#10
Mar 05, 2014, 06:11 pm Last Edit: Mar 06, 2014, 08:40 am by anv Reason: 1
A patch file is a file that indicates how to modify a given source code (or any text file) to obtain a new one with some changes.
Essentialy, a patch file contains data indicating something like "add this line, remove that one, etc.". It is generated by the unix command "diff" that compares two files and responds with this data. Having the patch file and the original file, one can use the command "patch" to obtain the modified version.
[edit] (found the patch file). I am applying it:
# cd /usr/share/arduino/hardware
# patch -p2 </home/anv/Descargas/usb_key_leds.diff
patching file arduino/cores/arduino/HID.cpp
patching file arduino/cores/arduino/USBAPI.h
Hunk #1 succeeded at 111 (offset -1 lines).
Hunk #2 succeeded at 131 (offset -1 lines).
Hunk #3 succeeded at 140 (offset -1 lines).
I'm attaching the result files
anv
I'm attaching the patched files resulting of applying usb_key_leds.diff to arduino version 1.0.5
Not tested it yet.
nonlinearmind
Once these files are replaced, how what code do we use in a sketch to listen for a num/scroll/caps lock led from the PC?
marcosmoran
hartmut_holzgraefe's code works like a charm. GREATE!
Thank you very much for sharing the code!
valeriog
Hi all,
I'm new to the Arduino world. I just bought an Arduino Micro and I was looking at a way to detect whether capslock has been set to ON on the host or not.
I don't understand how to use function getLedStatus in the patch provided by hartmut_holzgraefe to check the status of KEY_CAPS_LOCK, can you provide an example?
Many thanks in advance,
Valerio
