Topic: Robust Data Logging (Read 5291 times) previous topic - next topic
wwbrown
I am logging data onto a PC using serial I/O with the USB cable.  Robust means that when the power cycles the PC will automatically continue to log the data without user intervention.
Does anyone know of a Windows 7 application that would do this?
Thanks
wade
pito
Afaik in any OS you can set a program to be started after a boot..
HDowns
I've used Advanced Serial Data Logger is past. It can run as a service and will start before user login.
http://www.aggsoft.com/serial-data-logger.htm
Note about Serial-USB cable: they usually disconnect without any reason and do not work until you replug the cable.
supertechqc
Use the leonardo keyboard library to enter into excel cells.  For Linux freebee, use Gnumeric (comes with linux puppy).  These programs can perform dynamic analysis. :smiley-eek:
Don't get dismayed to Negative Activist!!!  These are usually Trolls who are first responders to your post.
