Topic: Encountered a bug in Arduino IDE 1.0.2 (Read 940 times) previous topic - next topic
Suma
Hi everyone  :)
i just came across a bug in Arduino IDE 1.0.2.
The bug was when you try to upload any code having the following line
Serial.print("ACCESS DENIED !!!");
or
Serial.println("ACCESS DENIED !!!");
the code compiles successful, but while uploading the process starts and later it hangs in between.
whereas the following code works fine
Serial.print("ACCESS DENIED !!");
and
Serial.println("ACCESS DENIED !!");
can anyone give it a try and let us know whether you encountered the same problem
sample code
Regards,
kS
"Progress isn't made by early risers. It's made by lazy men trying to find easier ways to do something." -Heinlein, Robert
Tom Carpenter
This has been discussed many many many times. There is a glitch in the Arduino Mega 1280 bootloader wherby if three ! are recieved in a row, the bootloader enters a funny mode and doesn't complete the upload.
Simple work around is to just not use "!!!" anywhere.
~Tom~
Suma
thanks tom for your valuable input. but mine was arduino mega2560 rev3.. i guess both share the same bootloader.
Regards,
kS
Louis Davis
This issue has been fixed, see here:
https://github.com/arduino/Arduino/issues/392
You will need to upload a new bootloader to your 2560 to fix the problem.
