Topic: one general question concerning RFID readers... (Read 649 times) previous topic - next topic
leKuk
maybe there are differences between different RFID readers, but i've been wondering what they report if there are several RFID tags in reach. do the tags interfere -> aren't readable , or is it possible to distinguish between them and read them one after the other?
in case there are differences between readers: i mean those that have been successfully used with arduino :-)
best, kuk
nima
Hi:
Using RFID in arduino is tricky because you will recieve a serial stream of 12 bits.   The way I got around this was to read the bits from the RFID and store it in a string array.
Each tag does have a unique ID and u can store the bits of the serial stream as characters.  So 'F' for 16 will be stored as the letter F.
-n
leKuk
hmm ok. thanks.
someone wrote that not all of those received 12 bits are necessarily important to distinguish between different tags. maybe you can write a function to cut it down to one byte and save only that one byte (8 bits i mean)...
concerning my question i understand that your rfid reader is sending 12bit bytes continuously. meaning that if there are three tags in reach it will send
- 12 bits describing tag "A"
then
- 12 bits describiing tag "B"
- 12 bits describing tag "C"
and then starting all over with tag "A" in a loop?
is that right?
beltran
hey nima,
I'm very courios to know your set up.
what reader are you using? how do you connect it to arduino?
b.
mrbbp
