Topic: Sensing wavelength of lights (Read 17441 times) previous topic - next topic
darudude
Hello all,
I haven't posted here for some time cause I've been busy with work, but I just thought of a great project for my Arduino and was looking to see if it was feasible.
The question is:
Is there a way to tell the intensity of a particular wavelength of light?
I've looked into photodiodes and phototransistors and haven't found something I could use. I need to be able to tell the intensity of various wavelengths of light and not just overall light intensity. I know a spectrometer would do this for me, but a good digital one is $10000, I'm looking to spend a couple bux lol
Any help would be appreciated. I'm looking for any feedback so don't hesitate to write your thoughts or ideas.
Reggie
I haven't tried it but this looks interesting:
http://www.cs.cmu.edu/~zhuxj/astro/html/spectrometer.html
darudude
Yeah I looked into it.
Couple things though. I wanted a more autonomous solution. To make this solution autonomous I would have to add a digital camera and do some software photo analysis, setting thresholds, etc. This solution would be more expensive and way too big for what I have in mind.
I was thinking of having an array of narrow wavelength photodiodes. As in one that detects 400nm, another that detects 450, another for 500, etc. Than each photodiode would only give me then intensity for that very narrow range of wavelength. However, I can't find photodiodes that have narrow wavelengths, they all seem to be made for a broad spectrum.
Grumpy_Mike
Quote
That is true due to the way photo electric effect works.
How about making your own spectrometer with a CD as a reflective diffraction grating. Then use a liner CCD array to detect the wavelength. I used a liner CCD array to count coins years ago so you could use the same type of circuit.
The schematic is here.
Reggie
You could also look at optical filters to display the bands that you want. Ha, Hb, OIII, etc. and/or block the ones you don't want UV, IR etc.
darudude
Hmm... I'm not exactly sure how a CCD works, I can't seem to find much literature on it. But how does it detect wavelength? I though its more of a size detector? Like isn't it an array of capacitors that get charged when photons hit it? if you block certain surface area, teh capacitors that don't get hit by light don't charge up? How does this help detect wavelength?
RanTalbott
That's a really clever idea, Mike.
How flat is the spectral response curve on the typical CCD?  Would you need to add a compensation table to adjust for its shape?
Ran
Grumpy_Mike
#7
Sep 07, 2009, 04:04 pm Last Edit: Sep 07, 2009, 04:05 pm by Grumpy_Mike Reason: 1
Quote
It's just an array of photo capacitors.
Quote
I said:-
Quote
So the wavelength is given by liner position, a line spectra would show up as a number of separate lines. The liner CCD sensor just detects the light intensity at any one position along the length of the sensor.
Quote
It's a TI device or just search for liner CCD. Alternatively you could rescue one from an old scanner.
Quote
I would have thought so.  ;)
oransen
You say:
"I'm not exactly sure how a CCD works, How does this help detect wavelength"
Imagine that the CCD is a long line of light detectors. Imagine you shine a rainbow on the CCD.  A part of the CCD will get red light, a part green light and so on. So the intensity of the different parts gives you the intensity of the different colors.
You can get your "rainbow" from a prism or, possibly, a bit of a broken CD or DVD.
borref
Quote
Interesting project - I will look forward to see what you find.
One approach could be to use multiple low cost LDR's, but add colored filter caps on each one. E.g. Red, Green, Blue or whatever wavelength equivalents you would need.
I also remember seeing (could not find it again) what I recall as a low cost color sensor that would give you the relative mix of wavelengths and through this allow you to determine color. This in combination with a broad spectrum LDR (for intensity) can perhaps also be of value.
RanTalbott
If memory serves,  Sparkfun sells something they call a "color sensor",  and Marlin P. Jones (mpja.com) had (has??) a surplus assembly with 3 photocells and color filters for about $5.  But it's been a few years since I saw the one at MPJA,  so it could well be sold out by now.
Ran
zooto68
Just use filters and a motorised filter wheel (as in astrophotography)
Grumpy_Mike
The trouble with the colour sensor is that it does not distinguish between different wavelengths in a line spectrum. These give you the RGB components in a continuous spectrum.
With the filter wheel, you need to use narrow band interference filters if there are more than two spectral lines viable at the same time.
ungravitational
What a great thread! I'll try the CD option and post any results.
