Topic: can't use Serial1 after pinMode(16.HIGH) (Read 1 time) previous topic - next topic
zeroun01
I am using TX2 and RX2 in serial communication.
But after setting  pin 16  to LOW , I can't reuse it in serial communication.
Here is my code for arduino due:
Code: [Select]
if (inputString1.equalsIgnoreCase("BREAK")) {
Serial2.end();
pinMode(16,OUTPUT);
digitalWrite(16,LOW);
delay(350);
Serial2.begin(baudeADP);
AWOL
That was a snippet of code, so here's a snippet of an answer: because.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
zeroun01
this is the complete code:
Code: [Select]
   Serial2.begin(4800);
   // read from port 0, send to port 2:
   if (Serial.available()) {
     int inByte = Serial.read();
     if(inByte == 'B')
      pinMode(16,OUTPUT); // using pin 16 as an output
      digitalWrite(16,HIGH);
      delay(350);
      Serial2.begin(4800); // using pin 16 again on serial communication
     Serial2.write(inByte);
   // read from port 2, send to port 0:
   if (Serial2.available()) {
     int inByte = Serial2.read();
     Serial.write(inByte);
RX2 (pin 17) is wired with TX2 (pin16).
This code allow the arduino to recieve bytes on port 0 and send it to port 2.
Recieving 'B', pin 16 is switched to pinmode and returning again to Serial mode.
Its works perfectly on mega board:
With Serial Monitor:
hi -> hi
B   -> B
hi  -> hi
But problems come with the Due board:
hi  -> hi
B   -> <nothing>
hi  -> <nothing>
