Topic: variable equal one but don't equal one (Read 2161 times) previous topic - next topic
abdallahbadarneh
Jun 27, 2013, 10:51 pm Last Edit: Jun 27, 2013, 11:21 pm by TTU.ABD Reason: 1
it's weird, the variable cursf1 equal one, but in (if) statement don't equal one, what's wrong?
double cursf;
void setup(){
  Serial.println("go");
  cursf=0.01;
  Serial.println(cursf);
  cursf=cursf*10;
  cursf=cursf*10;
  Serial.println(int(cursf));
  if(cursf==1)
  {Serial.println("hello");}
void loop(){}
the results on serial monitor:
go
0.01
1.00
johnwasser
The image didn't show up. Perhaps you can copy and paste some text that demonstrates the problem.
KeithRB
I can't see your code, but if it is a floating point variable, it is probably close to one, not exact.
Either use integers or code like this:
http://c-faq.com/fp/fpequal.html
abdallahbadarneh
KeithRB
Welcome to floating point!
As I have quoted before from Kernigham and Plauger _Elements of Programming Style_, "Floating point numbers are like sandpiles. Everytime you move one you lose a little sand and pick up a little dirt."
Also in your case, you are not comparing a floating point number to a floating point number, you are comparing a floating point number with the integer 1. You should use:
cursf == 1.0
Though it probably won't make a difference in this case, since the compiler will probably make the exact same code either way.
abdallahbadarneh
cursf == 1.0
I tried it [ if(cursf==1.0) ], but the results are the same.
GoForSmoke
Floating point is not exact. The more math you perform with it, the less exact it gets.
And btw, Arduino float and double are the same. 32-bit IEEE float.
As useless as it has been before I will mention to use fixed-point or choose smaller units and use integers. If I work in micro-meters (the unit, not the measuring tool) to achieve results in fractional meters then I will have 6 places accuracy and only need to add the decimal point for final output. A 32-bit signed integer (long) is good for 9 places.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
Tasking: techniques make the trees, the sketch is the woods.
See the woods and the trees, comment both.
abdallahbadarneh
I tried [ if(round(cursf)==1) ] , the result was right.
THANX.
JarkkoL
floats don't have infinite precision, thus when you write float x=0.01f; it's not exactly 0.01 but more like 0.0099999998f. It's generally not good idea to compare equality of floats (there are exception, but not in this case).
holmes4
instead of if(cursf==1) use if( (int)(cursf+0.5)==1)
Welcome to the world of floats ints and casts. Here's how it should work cursf is a float so the value will not be equal to 1 ever!. You should never ask if a float is equal to any thing ever. Greater or less than but never equal to.
Convert (casting) a float to an int all ways rounds DOWN never up or off so adding the 0.5 and then casting to an int will give you an int of 1 if cursf is between 0.5 and 1.4999.
Mark
KeithRB
Somehow, I don't think we got through to him.
