Topic: library 434 MHz wireless control power socket (non-dimmable only) (Read 2489 times) previous topic - next topic
picoPAN
Jun 28, 2013, 11:24 am Last Edit: Jul 01, 2013, 08:09 am by picoPAN Reason: 1
Hi guy,
recently I came to play around with these power sockets, you get to buy everywhere for little money.
They communicate over 434Mhz wireless.
I followed a tutorial by Dominik Krupke http://www.dserv01.de/howtos/funksteckdose-fernsteuern-mit-arduino/
It just worked out fine. (The non-dimmable sockets only!!! The dimmable ones operate with another protocol!)
For wiring up the sender, follow his instructions! Its is very straight forward.
Alternatively, use this datasheet:  http://www.sparkfun.com/datasheets/Wireless/General/MO-SAWR.pdf
On the basis of his tutorial and encrypted communication protocol I wrote a library for easy application in Arduino.
I hope, it helps you as much as it helped me!
Here is the header:
Code: [Select]
// library class header to control a wireless power socket
// set the binary encoding for identifier
// build control-stream for A, B, C, D: on and off
//use sender module http://www.sparkfun.com/datasheets/Wireless/General/MO-SAWR.pdf
// object instance call generates a power-socket object, taking the arguments VCC-pin, DATA-pin and a 5-bit indentifier prefix (32 different variations possible)
// library written by Paul Naethe, modified from original code by Dominik Krupke http://www.dserv01.de/howtos/funksteckdose-fernsteuern-mit-arduino/
// V 00.140.B  June 18th, 2013
#ifndef power_socket_h
#define power_socket_h
#include "Arduino.h"
class power_socket{
 private:
   void wait(int time);
   void sendByte(char input); //takes bit stream as a String, created from 5-bit indentifier prefix, channel and operation's mode postfix
   boolean sendCode(String code);
   void setChannel(char Channel);
   String _suffix;
   String _prefix;
   int rc_pin;
   int _vcc;        //
   int _overload;  //switches states for overloaded operation mode(s)
 public:
   power_socket(int VCC, int DATA, String prefix); //VCC and DATA pins, prefix a five-bit string e.g. 01001, as set at the socket.
   power_socket(int DATA, String prefix);          // overload constructor for permanent power supply on the VCC-pin, or operates the pin 12
   void init();                                    // needs to be called in the setup routine of the Arduino to set pins and serial connection
   void switchOn(char Channel);                    // takes a channel: A, B, C, D and operates the power socket
   void switchOff(char Channel);                   // takes a channel: A, B, C, D and operates the power socket
#endif
the source:
Code: [Select]
#include "power_socket.h"
power_socket::power_socket(int VCC, int DATA, String prefix){ //Prefix like "10001"
 rc_pin = DATA;
 _vcc = VCC;
 _prefix = prefix;
 _overload = 0;
power_socket::power_socket(int DATA, String prefix){ //Prefix like "10001"
 rc_pin = DATA;
 _prefix = prefix;
_overload = 1;
void power_socket::init(){
 pinMode(13,OUTPUT);
 Serial.print("sensor connecting... data pin: ");
 pinMode(rc_pin, OUTPUT);
 Serial.println(rc_pin);
 if(_overload == 0){
 Serial.print("power pin: ");
 pinMode(_vcc, OUTPUT);
 Serial.println(_vcc);
void power_socket::switchOn(char Channel){
 setChannel(Channel);
 String output = _prefix + _suffix + "10x" ;
 Serial.println(output);   //debugging
 sendCode(output);
void power_socket::switchOff(char Channel){
 String output = _prefix + _suffix + "01x" ;
 sendCode(output);
boolean power_socket::sendCode(String code){ //empfange den Code in Form eines Char[]
 digitalWrite(13, HIGH);
 digitalWrite(_vcc, HIGH);
 for(byte z = 0; z<7; z++){ //wiederhole den Code 7x
   for(byte i = 0; i<13; i++){ //ein Code besteht aus 12bits plus "x"
     sendByte(code[i]);
 //sendByte('x'); //da der code immer mit x/sync abschliesst, brauchen wir den nicht im code und haengen es automatisch immer hinten ran.
 digitalWrite(_vcc, LOW);
 digitalWrite(13, LOW);
 return true;
void power_socket::sendByte(char i) { //Diese Funktion soll 0,1 oder x senden koennen. Wir speichern die gewuenschte Ausgabe in der Variabel i
 switch(i){ //nun gucken wir was i ist
 case '0':{ //Der Code fuer '0'
   digitalWrite(rc_pin,HIGH);
   wait(1); //da die Pausen x*350us lang sind, machen wir daraus eine Funktion
   digitalWrite(rc_pin,LOW);
   wait(3);
   wait(3);
   wait(1);
   return;
 case '1':{ //Der Code fuer '1'
   wait(1);
   wait(3);
   wait(1);
   wait(3);
   return;
 case 'x':{ //Der Code fuer x(sync)
   wait(1);
   wait(31);
void power_socket::wait(int x) {
 delayMicroseconds(x*350); //warte x*350us
void power_socket::setChannel(char Channel){
 switch (Channel){
   case 'A':{
     _suffix = "10000";
   case 'B':{
     _suffix = "01000";
   case 'C':{
     _suffix = "00100";
   case 'D':{
     _suffix = "00010";
   default: {
     _suffix = "00000";
     Serial.println("ERROR: no valid Channel: should be 'A', 'B', 'C' or 'D'.");
And an example:
Code: [Select]
/*Arduio skech demonstrtating the power_socket library,
switching on the socket everytime the Arduiono gets powered.
V1.2, June 18th, 2013, by Paul Naethe
char channel = 'C';
String identifier = "00000";
power_socket Socket(11, 12, identifier); //assigning VCC-pin(11) and DATA-pin(12)
enum State {OFF, ON} state;  //creating state-variable
void setup(){
 Socket.init();
 Socket.switchOn(channel);
 state = ON;
void loop(){
Cheers!
